Face.CalculateStrokes() not working
william
william
I have this code...
Dim oDoc As PartDocument = ThisDoc.Document
Dim oCompDef = oDoc.ComponentDefinition
Dim entity = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select a Face")
oDoc.SelectSet.Select(entity)
Dim oFace As Face
Try
	oFace = ThisApplication.ActiveDocument.SelectSet.Item(1)
Catch
	MsgBox("A face must be selected.")
End Try
Dim lVertexCount As Long
Dim lSegmentCount As Long
Dim adVertexCoords() As Double
Dim alVertexIndices() As Long
oFace.CalculateStrokes(0.01, lVertexCount, lSegmentCount, adVertexCoords, alVertexIndices)
And I keep getting this error
According to the API help the vertexindices are supposed to be 'Long'
However the code tooltip says the vertexindices are type integer.
When I change vertexindices to integer and run the rule I get this error.
Can someone confirm what this should be and how to make it work?
Michael.Navara
Difference between Integer and Long is in its size. In VBA the Integer is 16bit and in iLogic/VB.NET Integer is 32bit length. This means VBA Long is the same as VB.NET Integer.
At second you need to initialize the arrays before. See the iLogic sample below.
Sample code
Dim oFace As Face
Try
Catch
End Try
Dim adVertexCoords() As Double = {}
Dim alVertexIndices() As Integer = {}
'FOR DEBUG ONLY
Logger.Debug("lVertexCount = " & lVertexCount)
Logger.Debug("lSegmentCount = " & lSegmentCount)
Logger.Debug("adVertexCoords = Double(" & adVertexCoords.Length & ")")
Logger.Debug("alVertexIndices = Double(" & alVertexIndices.Length & ")")
william
Thanks. I wouldn't have picked that.
