Extrusion Profile Selection/Color Adjustment
dwest
dwest
I have noticed that it is difficult sometimes to visualize the profile I am selecting for an extrusion because of the similar shading with the rest of the part.  Is there a way to adjust the color of the profile selection.  I went into "Options" and looked under the colors & display tabs, but was unsuccessful.
Thanks for your help,
Dale
HermJan.Otterman
Hello Dale,
there are a view color scheme's
for the extrusion command, the highlight color is red, accept for the scheme "winter night" that is grey.
there is only a hard way to change these predefined colors, and that is through "hacking" the windows registry.
before doing that, create a copy first.
look for:
HKEY_CURRENT_USER\SOFTWARE\Autodesk\Inventor\RegistryVersion21.0\System\Preferences\ColorSchemes\Schemes
and than it is try and error,
the numbers stand for the different color scheme's.
look for : PrimarySelectColor  or HighlightColor  ...
(there is an old tool somewhere in the SDK folder, DONT use that, because it will kill you settings!)
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
cristian.herreraMLHUY
Community Visitor
Community Visitor
File-Options-Colors-Customize Schemes-Selection-Highlight (double click and select color) - apply-close.
dwest
I actually did find out how to change the selection color in Inventor.  You need to go to Tools>Application Options>Customize Schemes>Expand the Selection option under Graphical Elements>Highlight.  If you click on the color swatch for the Highlight option you can change the color to whatever you like.  See image.
