coincident sketch constraint
Hi, I have the below code to add coincident constraints between the start point of two sketch lines and a center point of a projected circle. I use the two lines to create a section view. The code works for the first coincident constraint, but when it tries to do the second one I get this: "Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))". Why does it fail?
'Draws the first section line
		oSectionLine = oSectionSketch.SketchLines.AddByTwoPoints(
			oTG.CreatePoint2d(Point1.X,Point1.Y),
			oTG.CreatePoint2d(Point2.X,Point2.Y))
		'Draws the second section line
		oSectionLine2 = oSectionSketch.SketchLines.AddByTwoPoints(
			oTG.CreatePoint2d(Point3.X,Point3.Y))
		'Adds coincident constraints.
		oSectionSketch.GeometricConstraints.AddCoincident(
			oCircularEntity.CenterSketchPoint,
			oSectionLine.StartSketchPoint)
			oSectionLine2.StartSketchPoint,
			oCircularEntity.CenterSketchPoint)
This is really weird.. If I do it like the code abode then the code creates the constraints, but I get the above error message..I try to move the sketch lines, and they are constrained even tho I get error message..
When I simply put it into a Try, Catch, End Try config it works, but it is sketchy because something is obviosuly wrong, but I cant figure it out..!
dg2405
For two lines you have to use the "Merge" method instead of usinge the "AddCoincident".
Call oSectionLine.StartSketchPoint.Merge(oSectionLine2.StartSketchPoint)
