Extrude Feature using Project Geometry Profile
luccla
luccla
Below is the code and the image after I've run the code.
I would like to use ilogic to extrude from the top surface using the projected geometry/edges as the profile.
When I try to create extrude feature, I get error. And I'm not sure how to trouble shoot.
Sub Main()
	Dim pdoc As PartDocument
	pdoc = ThisApplication.ActiveDocument
	Dim comDef As PartComponentDefinition
	comDef = pdoc.ComponentDefinition
	Dim sketches As PlanarSketches
	sketches = comDef.Sketches
	Dim feats As PartFeatures
	feats = comDef.Features
	Dim derive As DerivedAssemblyComponents
	derive = comDef.ReferenceComponents.DerivedAssemblyComponents
	Dim surfaces As SurfaceBody
	surfaces = comDef.SurfaceBodies.Item(1)
	sketches.Item("TOP_SURFACE").Delete
	Dim i As Integer = 1
	Dim top(2) As Face
	top(0) = Nothing
	top(1) = Nothing
	Dim n As Integer
	n = 1
	While i < surfaces.Faces.Count
			If surfaces.Faces.Item(i).EdgeLoops.Count > 1 Then
				top(n - 1) = surfaces.Faces.Item(i)
				n = n + 1
			End If
		i = i + 1
	End While
	Dim sketch As PlanarSketch
	sketch = sketches.Add(top(1),True)
	sketches.Item(1).Name = "TOP_SURFACE"
'	Dim profile As Profile
'	profile = sketch.Profiles.AddForSurface
'	Dim def As ExtrudeDefinition
'	def = feats.ExtrudeFeatures.CreateExtrudeDefinition(profile, kJoinOperation)
'	feats.ExtrudeFeatures.Add(def)
End Sub
The image below is the desired effect, but it does it automatically through ilogic rule.
Any assistance would be greatly appreciated.
Thank you
Curtis_Waguespack
Hi @luccla,
I'm sure this isn't exactly what you are after, but attached is a quick example of the syntax for creating an extruded surface.
I hope this helps.
Curtis
Try
Catch
End Try
Try
	feats.Item("Test").Delete
Catch
End Try
Dim top As Face
top = surfaces.Faces.Item(29)
sketch = sketches.Add(top, True)
sketch.Name = "TOP_SURFACE"
def = feats.ExtrudeFeatures.CreateExtrudeDefinition(profile, PartFeatureOperationEnum.kSurfaceOperation)
def.SetDistanceExtent(1, PartFeatureExtentDirectionEnum.kPositiveExtentDirection)
Dim oExtrude As ExtrudeFeature
oExtrude = feats.ExtrudeFeatures.Add(def)
oExtrude.Name = "Test"
luccla
I applied some of your code, but so much has changed. I
It's only creating one edge loop now, and it's creating a second sketch.
This is what I changed the code too.
Sub Main()
	Try
	Catch
	End Try
	Try
	Catch
	End Try
	Dim top(2) As Face
	top(0) = Nothing
	top(1) = Nothing
	Dim n As Integer
	n = 1
				n = n + 1
			End If
		i = i + 1
	End While
	def = feats.ExtrudeFeatures.CreateExtrudeDefinition(profile, PartFeatureOperationEnum.kJoinOperation)
End Sub
The upside, something happened that wasn't an error. Noice. Baby steps.
luccla
Okay Curtis,
My initial reply was bad, I made multiple mistakes.
But, I think I figured it out.
I used your code, but instead of:
I changed it to:
profile = sketch.Profiles.AddForSolid
Additionally, I changed:
to this:
I'm not entirely sure I understand, but it works.
I hope this was informative for you.
