Extract Occurrence Orientation Angle to Assembly Origin Plane
petestrycharske
Advisor Advisor
petestrycharske
All,
Good afternoon!  I'm working with Inventor, specifically factory assets within Inventor and want to extract the angle between one of my model's YZ - Plane and the Assembly's YZ - Plane.  I can see it in the component iProperties >> Occurrence tab, but am not finding a way to extract that value via iLogic.  I found this post, but it seems really complicated, and I just want to capture that angle value.  If there's no other way, so be it, but am hoping for something not as involved.  I'm not a programmer, so feel free to chuckle if I'm being naive, but thought I would just see what could be done.  If you have any questions, please do not hesitate to contact me.  Hope all is well and have a most blessed day!
Peace,
Pete
Just a guy on a couch...
Please give a kudos if helpful and mark as a solution if somehow I got it right.
chandra.shekar.g
Autodesk Support
Autodesk Support
@petestrycharske,
Try below iLogic code to get angle between YZ plane of model and YZ plane of assembly.
Dim oDoc = ThisAssembly.Document
Dim oDef = oDoc.ComponentDefinition
Dim oAssyPlane = oDef.WorkPlanes.Item("YZ Plane")
'Assuming that first occurrence is used for angle measurement
Dim occ = oDef.Occurrences.Item(1)
Dim occDef = occ.Definition
Dim occPlane = occDef.WorkPLanes.Item("YZ Plane")
Dim oPlaneProxy As WorkPlaneProxy
occ.CreateGeometryProxy(occPlane, oPlaneProxy)
Dim oTool As MeasureTools
oTool = ThisApplication.MeasureTools
Dim angle As Double
'Angle in radians
angle = oTool.GetAngle(oAssyPlane, oPlaneProxy)
'Angle in deg
angle = (angle * 180) / 3.14
MessageBox.Show("Angle : " & Format(angle, 0#) & " in deg")
Note: Code is developed in Inventor 2019.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
petestrycharske
Thanks @chandra.shekar.g!  That worked exactly as I needed it to!  Have an awesome and most blessed day!
