Extract Frame generator assembly/weldment title field to the parts custom field
I have a frame generated frame that is pulled into an upper level assembly where things are then attached to it. I need to grab the upper level assembly title, or just the frame generated assembly title, and then loop through and apply that to the placed members custom iproperty called "Section" I am blanking on how to accomplish this.
Due to our syntax, it will always use the right (4) characters of the title field. So I was planning on using the right function once I got the property, but I am stuck. Any guidance will be appreciated!
Autodesk Certified Professional
