Extract Frame generator assembly/weldment title field to the parts custom field
blandb
Mentor Mentor
blandb
I have a frame generated frame that is pulled into an upper level assembly where things are then attached to it. I need to grab the upper level assembly title, or just the frame generated assembly title, and then loop through and apply that to the placed members custom iproperty called "Section" I am blanking on how to accomplish this.
Due to our syntax, it will always use the right (4) characters of the title field. So I was planning on using the right function once I got the property, but I am stuck. Any guidance will be appreciated!
Autodesk Certified Professional
Curtis_Waguespack
Hi @blandb
Here's a link that has an example that should get you pointed in the right direction on accessing the properties of the frame members:
https://forums.autodesk.com/t5/inventor-customization/ilogic-rule-for-changing-frame-member-part-num...
I hope this helps.
Curtis
blandb
I'm not certain, but doesn't that code use the frame members to develop a part number? I am trying to just pull the title from the assembly of the frame weldment (where the members are inserted) and then place that title into each members custom iproperty.
blandb
I believe I got something that works!
Dim asmDoc As AssemblyDocument = ThisDoc.Document
Dim childDoc As Document
For Each childDoc In asmDoc.AllReferencedDocuments
	Try
		Dim filename = IO.Path.GetFileName(childDoc.FullFileName)
		iProperties.Value(filename, "Custom", "RAIL SECTION") = right(iProperties.Value(asmDoc, "Summary", "Title"),4)
	Catch
	End Try
Next
