Hello all I am not sure if this is possible or maybe I'm not wording the search right, but is there a way for iLogic to extract a list of a key column in an iPart Factory from a member in an assembly?
For example I'd like to be able to select an iPart custom or not and have iLogic grab and array list of a particular key value.
I would like the iLogic code to make an array list of the 'MATL' key column made up of the three options that I can then use in an 'Input List' to select a different material.
Anyone know what I'm talking about. This should be easy but I can't seem to find any code that will do that.
Thanks for your help.
