Check if model haven't description from drawing then add description in drawing and copy to model
Hi i've made this rules to do the description job.
The rule work well to add description in drawing and copy to model but i don't know why the description of model from drawing doesn't work very well. Can someone help me please?
Thank you
Dim oDDoc As DrawingDocument = ThisDrawing.Document
'Getting the description of the active drawing document, without checking if it is empty
Dim oDrawingDesc As String = iProperties.Value("Project", "Description")
'Getting the active sheet of the active drawing
Dim oSheet As Sheet = oDDoc.ActiveSheet
'Getting the first view that was placed into the drawing (you could specify the drawings name here too inside "" marks)
Dim oView As DrawingView = oSheet.DrawingViews.Item(1)
'Getting the document being represented within the view
Dim oVDoc As Document = oView.ReferencedDocumentDescriptor.ReferencedDocument
'ThisDoc.Launch(oVDoc.FullFileName)
'Getting the model documents description iProperty value the shorter way, without checking if it is empty
Dim oVDesc As String = iProperties.Value(oVDoc, "Project", "Description")
If oVDesc = "" Then
    myparam = InputBox("Manca la descrizione", "Descrizione mancante", "")
     iProperties.Value("Project", "Description") = myparam
     InventorVb.DocumentUpdate()
'System.Threading.Thread.CurrentThread.Sleep(1000)
iLogicVb.RunExternalRule("provissima")
second rule triggered at the end of first
Sub Main()
    If Not ThisApplication.ActiveDocument.DocumentType = DocumentTypeEnum.kDrawingDocumentObject Then
        MessageBox.Show("Current document is not drawing docuemnt", "Inventor")
        Exit Sub
    Dim value_List As List(Of String) = New List(Of String)
    value_List.Add (iProperties.Value("Project", "Description"))
    Dim oDoc As Document
    oDoc = ThisDrawing.ModelDocument
    If oDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
        Update_Properties(oDoc,  value_List)
        Dim oAsyDoc As AssemblyDocument
        oAsyDoc = oDoc
        Dim oReferDoc As Document
        Dim occ As ComponentOccurrence
        Dim oDef As AssemblyComponentDefinition
        oDef = oAsyDoc.ComponentDefinition
        For Each occ In oDef.Occurrences
            If occ.SubOccurrences.Count = 0 Then
                oReferDoc = occ.ReferencedDocumentDescriptor.ReferencedDocument
                Update_Properties(oReferDoc, value_List)
            Else
                processAllSubOcc(occ,  value_List)
        Next
    Else If oDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
End Sub
Private Sub processAllSubOcc(ByVal oCompOcc As ComponentOccurrence , value_List As List(Of String))
    Dim oSubCompOcc As ComponentOccurrence
    For Each oSubCompOcc In oCompOcc.SubOccurrences
        If oSubCompOcc.SubOccurrences.Count = 0 Then
            oReferDoc = oSubCompOcc.ReferencedDocumentDescriptor.ReferencedDocument
            Update_Properties(oReferDoc,value_List)
        Else
            Update_Properties(oReferDoc ,value_List)
            Call processAllSubOcc(oSubCompOcc, value_List)
    Next
End Sub
Sub Update_Properties(oDoc As Document,   value_List As List(Of String))
    oDoc.PropertySets.Item("Design Tracking Properties").Item("Description").Value = value_List.Item(0)
    oDoc.Save()
End Sub
I've solved by myself.
If someone need it
Dim oDoc As DrawingDocument = ThisDoc.Document
Dim oSheet As Sheet = oDoc.ActiveSheet
If oView Is Nothing Then Exit Sub
oModelDoc = oView.ReferencedDocumentDescriptor.ReferencedDocument
'Get the properties of the reference model of the view
oDescripProp = oModelDoc.PropertySets.Item("Design Tracking Properties").Item("Description").Value
If oDescripProp = "" Then
	oModelDoc.PropertySets.Item("Design Tracking Properties").Item("Description").Value = myparam
