External Ilogic rules problem
Charlies_3D_T
Charlies_3D_T
Hello Guys,
I need some help or ideas. I am trying to change to using external ilogic rules.
i have an PDF and DWG export rule. They both work perfect when i have them in the templates but when i transfer them to an external rule it's not working.
Do you guys have any idea what i need to check or what can cause this that rules are not working?
thank you!
Charlie
Sergio.D.Suárez
Hi, can you attach your rule to see if we can identify the problem?
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
chandra.shekar.g
Autodesk Support
Autodesk Support
@Charlies_3D_T ,
Can you please share non confidential file and iLogic rule to test the behavior?
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
