Export weldment Information incl geometrie
theo_bot
theo_bot
Hi there, Does Anybody has Some experience with the api and weldments? we want to export weldinformation including geometry Information to XML. We Will import this in à weld automation program for weld robots. The basic weld information is accessible tru the api. For cosmetic weld we can extract the geometrie Information (start point, end point, type line or arc etc.) But the "solid weld" doesn't give us the info. Is there some experience About this?
xiaodong_liang
Autodesk Support
Autodesk Support
Hope the code below helps:
Sub test()
Dim oDoc As AssemblyDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oAssDef As WeldmentComponentDefinition
Set oAssDef = oDoc.ComponentDefinition
Dim oSolidWeld As WeldBead
Dim oCosmeticWeld As CosmeticWeld
For Each oSolidWeld In oAssDef.Welds.WeldBeads
  Dim oEachBeadFace As Face
  For Each oBeadFace In oSolidWeld.BeadFaces
      'oBeadFace.Edges....
  Next
Next
For Each oCosmeticWeld In oAssDef.Welds.CosmeticWelds
  Dim oEdge As Edge
  For Each oEdge In oCosmeticWeld.Edges
    ' dump the info of the edge
  Next
Next
End Sub
