Export to dxf, in separate folders by thickness
kresh.bell
Message 1 of 8
kresh.bell
Would anyone know how to edit exist iLogic or do a new one that would be exported to dxf but not all in one folder rather than folders according to the thickness of the material, in one folder all flat pattern of the same thickness
Replies (7)
Message 2 of 8
Sergio.D.Suárez
Hi, try this code to run it from an assembly, look for all reference files of sheet metal, export them to dxf without Bend lines or tangent lines. Group the sheets into folders by thickness and material. You can place a revision to your sheetmetals.
Sub Main()
    Dim New_Folder_Path As String = ThisDoc.Path
    Dim oAsmDoc As AssemblyDocument = ThisDoc.Document
    My.Computer.FileSystem.CreateDirectory(New_Folder_Path)
    'Ask user for REV level
    Dim Rev_Level As String = ""
    Rev_Level = InputBox ("Enter Rev Level","Creating DXF files For Entire Assembly")
    Dim Count_up As Integer = 0
    Dim Gauge_Folders(12) As String
    Dim Ga As String
    Dim doc As Document
	Dim R_Part As String
	Dim oMaterial As Material
    For Each doc In oAsmDoc.AllReferencedDocuments
        If doc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
			Try
				R_Part = doc.DisplayName
				oMaterial = doc.ComponentDefinition.Material
				Gauge_Path = New_Folder_Path & "\" & Parameter(R_Part, "Thickness") & " " & oMaterial.Name
							MessageBox.Show(Gauge_Path )
				Try
					My.Computer.FileSystem.CreateDirectory(Gauge_Path)
				Catch
				End Try
            	Call Make_DXF(doc, Rev_Level, Gauge_Path)
			Catch
			End Try
		End If
    Next
MsgBox("DXF Export Complete",,"All Done")
End Sub
Sub Make_DXF(oDoc As Document, Rev_L As String, File_Location As String)
	ThisApplication.Documents.Open(oDoc.FullFileName, True)
	Dim Part_Name As String = oDoc.DisplayName
	Dim TestPos As Integer = 0
	Dim Rev_Adder As String = ""
	If Rev_L <> "" Then Rev_Adder = " REV " & Rev_L
	TestPos = InStr(1, Part_Name, ".")
	If TestPos <> 0 Then Part_Name = Left(Part_Name, InStr(Part_Name, ".")-1)
	Dim New_Name As String = Part_Name
	Dim oFilename As String  = File_Location & "\" & New_Name & Rev_Adder & ".dxf"
	Dim oCompDef As SheetMetalComponentDefinition = oDoc.ComponentDefinition
	If oCompDef.HasFlatPattern = False Then
		oCompDef.Unfold
	Else
		oCompDef.FlatPattern.Edit
	End If
	Dim oFlatPattern As FlatPattern = oCompDef.FlatPattern
	Dim oFace As Face = oFlatPattern.TopFace
	Dim oCommand As CommandManager = ThisApplication.CommandManager
	oCommand.DoSelect(oFace)
	oCommand.PostPrivateEvent(PrivateEventTypeEnum.kFileNameEvent,oFilename)
	oCommand.ControlDefinitions.Item("GeomToDXFCommand").Execute2(True)
	oCompDef.FlatPattern.ExitEdit
	oDoc.Close
End Sub
 I hope this helps your work. regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Message 3 of 8
kresh.bell
Hi Sergio,
sorry for delay, very very good, really great, thank you very much, it is extremely good and useful iLogic
Message 4 of 8
Moverano
How could the code be tweaked so that it does not have to be accepted for each piece?
great job
Message 5 of 8
ersin_karacoban
I would like to write the number of pieces next to the exported DXF file. Can you help me with this?
For example; 2103 02 04 - 16 QTY
Message 6 of 8
DeptaM
Good day,
where are dxf files saved?
Thank you
Message 7 of 8
ersin_karacoban
It extracts to the folder with the assembly file.
Message 8 of 8
DeptaM
Good day,
everything goes but no .dxf file is exported. I have Inventor 2023
