Export to 3D PDF Sample C# Code from the Documentation is not working.
jmacapagal2CD9H
jmacapagal2CD9H
Good day!
I've been working on Exporting to 3d pdf using AnarkCore, however, using the provided sample C# codes from the documentation is not working when I try to use it from a custom addin that I created. Below is the actual error. Do you have any Ideas?
Thank you.
Zach.Stauffer
I don't have any experience with this personally, but what I would try is to comment out the "oOptions.Value" lines one at a time until it works, and then you'll know which option setting it doesn't like. Once you know that it is easier to figure out why it's not working.
jmacapagal2CD9H
It does not work if I use the same code from the custom addin that I created but, somehow works from a simple application that I made.
jmacapagal2CD9H
Declare the oDoc as dynamic ex: dynamic oDoc = mApp.ActiveDocument. Answer came from the Dev support
