Case not working in Master Assembly
christof.gosselin
christof.gosselin
Hi all,
I'm working on a product configurator for our company and would like to automate the flanged connection. In the master assembly i have a reference to a sub assembly where the flane is placed (See picture)
i also coded this part so the FFG_Connection is the same in the master assembly as in the sub assembly .
in the sub assembly i made a case for the flanges (See picture)
and now if i run the code in the MASTER ASSEMBLY it doesn't seem to work? is there something that i am missing?
hope someone can help 🙂
Christof
dalton98
I cant see an obvious problem. I'm assuming the different case components represent the same part. So you unsuppress the one you want shown. It might work if you try 'ManageComponents', this doesn't require any suppression, but you do have to name your geometry mates. Here's an example from a course I took on iLogic:
ThisAssembly.BeginManage("Group 1")
If BitType = "Flat"
	Dim componentB = Components.Add("Bit", "screwdriver_bit_Flat.ipt")
ElseIf BitType = "Robertson"
	Dim componentB = Components.Add("Bit", "screwdriver_bit_Robertson.ipt")
ElseIf BitType = "TorxSmall"
	Dim componentB = Components.Add("Bit", "screwdriver_bit_TorxSmall.ipt")
ElseIf BitType = "TorxStandard"
	Dim componentB = Components.Add("Bit", "screwdriver_bit_TorxStandard.ipt")
ThisAssembly.EndManage("Group 1")
Constraints.AddMate("Mate1", "Bit", "MateFace2", "screwdriver_body:1", "MateFace2")
Constraints.AddMate("Mate2", "Bit", "Work Point2", "screwdriver_body:1", "Work Point2")
'iProperties.InstanceValue("Part1:1", "PropertyName_Text") = "5"
