Export Sketch to DXF and Control Entity target layers
JoeBarnes4076
JoeBarnes4076
Is there any way to export a sketch to DXF and control the target layer of sketch entities?
Solid Lines go to Layer=0
Construction Lines go to Layer=Construction
Center Lines go to Layer=Center
I am currently using
           Sketch.DataIO.WriteDataToFile("DXF", strDXFOutputFile)
which send everything to layer=0
Joe
adam.nagy
Autodesk Support
Autodesk Support
Unfortunately, it does not seem possible.
In the user interface as well, though you can use a settings xml file in the "DXF File Export Options" dialog under "Customize DWG/DXF", it seems to only control layer related settings in case of flat pattern export.
You could however programmatically edit the created DXF file to create those layers and set the entity layers accordingly: http://usa.autodesk.com/adsk/servlet/item?linkID=10809853&id=12272454&siteID=123112
Sorry for the bad news.
Cheers,
Adam Nagy
Autodesk Platform Services
