Export Sketch as DXF using iLogic
I have a Sketch (Skizze) at Assembly level and I would like to export the sketch as .dxf file using iLogic.
The iLogic snippet,"Export DXF from IDW" which has an DXFAddIn.SaveCopyAs can not be used because I do not have any drawing sheets.
(Please excuse me as the picture is in German)
Any ideas or suggestions are much appreciated.
Thank you,
Yatish.
mcgyvr
How about this.. Simply exports the first sketch to the C:\Temp folder
     AssyDoc = ThisApplication.ActiveDocument
     ' Get the first sketch in the assembly.
     Dim sketch As PlanarSketch
     sketch = AssyDoc.ComponentDefinition.Sketches.Item(1)
     ' Write the sketch out as DXF.
     Call sketch.DataIO.WriteDataToFile("DXF", "C:\Temp\Sketch1.dxf")
	 MessageBox.Show("Sketch Created", "Sketch Creation Notification")
JelteDeJong
You can try this.
Dim fileName As String = "c:\temp\Skizze.dxf"
Dim doc As AssemblyDocument = ThisDoc.Document
Dim sketch As PlanarSketch = doc.ComponentDefinition.Sketches.Item("Skizze")
Dim sOut As String = "DXF"
sketch.DataIO.WriteDataToFile(sOut, fileName)
Edit:
i didnt see the solution by @mcgyvr when i replyed but it is the same as mine
Jelte de Jong
Blog: hjalte.nl - github.com
@mcgyvr Thank you. The Solution has worked.
