A Macro that updates\runs all ilogic in a drawing.
JonnyPot
Message 1 of 9
JonnyPot
Accepted solutions (3)
Replies (8)
Message 2 of 9
JhoelForshav
Hi @JonnyPot
Are you looking for something like this? 🙂
Sub RunIlogicRules()
Dim oDoc As DrawingDocument
Set oDoc = ThisApplication.ActiveDocument
If oDoc.DocumentType = kDrawingDocumentObject Then
Dim iLogicAuto As Object
Dim oAddin As ApplicationAddIn
For Each oAddin In ThisApplication.ApplicationAddIns
    If (oAddin.ClassIdString = "{3BDD8D79-2179-4B11-8A5A-257B1C0263AC}") Then
    Exit For
Next
Set iLogicAuto = oAddin.Automation
Dim oRules As Object
Set oRules = iLogicAuto.Rules(oDoc)
Dim oRule As Object
For Each oRule In oRules
    Call iLogicAuto.RunRule(oDoc, oRule.Name)
Next
End Sub
Message 3 of 9
JonnyPot
hello @JhoelForshav. i was going to implement this code in a other Macro that you made, but it seems that it's a bit more complicated than i thoght‌‌ 😅. can you help me with it, thank you.
Macro:
Sub iPart_DWG_STP()
Dim oDrawing As DrawingDocument
Set oDrawing = ThisApplication.ActiveDocument
Dim oPath As String
oPath = "C:\Users\hfljf\Desktop\TestFolder" 'Folder to save the drawings
Dim oView As DrawingView
Dim oDoc As Document
Dim oFactory As iPartFactory
For Each oView In oDrawing.ActiveSheet.DrawingViews
    Set oDoc = oView.ReferencedDocumentDescriptor.ReferencedDocument
    On Error GoTo trynext
    Set oFactory = oDoc.ComponentDefinition.iPartMember.ParentFactory
    Exit For
trynext:
Next
    If oFactory Is Nothing = False Then
    Dim oRow As iPartTableRow
    For Each oRow In oFactory.TableRows
        On Error GoTo nextView
        If oView.ActiveMemberName <> oRow.MemberName Then oView.ActiveMemberName = oRow.MemberName
        Call oDrawing.Update
        Do While oView.IsUpdateComplete = False
            Call ThisApplication.UserInterfaceManager.DoEvents
        Loop
nextView:
    Next
    Call oDrawing.SaveAs(oPath & "\" & oRow.MemberName & ".dwg", True)
    Dim oMember As PartDocument
    Set oMember = ThisApplication.Documents.ItemByName(oFactory.MemberCacheDir & "\" & oRow.PartName)
    Call oMember.SaveAs(oPath & "\" & oRow.MemberName & ".stp", True)
Next
End Sub
Message 4 of 9
JhoelForshav
@JonnyPot
I'm not able to test the macro right now, but I think something like this should work. Let me know 🙂
Sub iPart_DWG_STP()
Dim oPath As String
Dim oSheet As Sheet
Set oSheet = oDrawing.ActiveSheet
    Exit For
Next
Set oRules = iLogicAuto.Rules(oDrawing)
Dim oRule As Object
For Each oView In oSheet.DrawingViews
    Exit For
trynext:
Next
        Loop
nextView:
    Next
    Call iLogicAuto.RunRule(oDrawing, oRule.Name)
Next
Next
End Sub
Message 5 of 9
JonnyPot
@JhoelForshav
It updates the ilogic in the drawing but it bypasses the update of the 3D model.
Message 6 of 9
JhoelForshav
@JonnyPot
I don't understand what you mean? are you talking about the iLogic rules in the iPart-factory? Like we did here?:
https://forums.autodesk.com/t5/inventor-customization/macro-that-creates-drawings-dosent-updeite-ilo...
Because the code you posted earlier in this thread is not the same...
Message 7 of 9
JonnyPot
yes, i am very sorry 😐, is it posseble to change the other one?
Message 8 of 9
JhoelForshav
@JonnyPot
Again, I havn't tried it but this should work - It's basically the same macro
Sub iPartDWG()
ThisApplication.SilentOperation = True
Dim oPath As String
oPath = "C:\VaultWorkingFolder\Designs\Temp\Jhoel\iPartTest\Drawings" 'Folder to save the drawings
Dim oDoc As PartDocument
    Exit For
Next
Dim oRule As Object
Set oDoc = ThisApplication.Documents.Open(oFactory.Parent.FullFileName)
Exit For
trynext:
Next
oDoc.ComponentDefinition.iPartFactory.DefaultRow = oRow
Call oDoc.Update
Call oDoc.Save
Call oDrawing.Update2
Loop
nextView:
Next
Next
Next
Call oDoc.Close
ThisApplication.SilentOperation = False
End Sub
Message 9 of 9
JonnyPot
@JhoelForshav
Thank you it works very well.
In another note i noticed this very weird bug that after a few drawings it rights the previous drawing description, as shown in the print screen (witch is determined by the parameters of the iPart).
