Export Sketch As AutoCAD Dwg file Question
isocam
isocam
Can  anybody help?
I have the following VBA code to export a "Sketch" as a AutoCAD Dwg file.....
   Dim DWGAddIn As TranslatorAddIn
       Set DWGAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC2-122E-11D5-8E91-0010B541CD80}")
       Set Doc = ThisApplication.ActiveDocument
       Dim transObjs As TransientObjects
       Set transObjs = ThisApplication.TransientObjects
       Dim context As TranslationContext
       Set context = transObjs.CreateTranslationContext
       context.Type = kFileBrowseIOMechanism
       Dim options As NameValueMap
       Set options = transObjs.CreateNameValueMap
       If DWGAddIn.HasSaveCopyAsOptions(Doc, context, options) Then
          options.Value("Sketch") = True
          options.Value("DwgVersion") = 25
       End If
       Dim oDataMedium As DataMedium
       Set oDataMedium = transObjs.CreateDataMedium
       oDataMedium.FileName = DwgFileName
       Call DWGAddIn.SaveCopyAs(Doc, context, options, oDataMedium)
    End If
The AutoCAD Dwg file is exported as a 3d solid!
How can I export the "Sketch" so that it exports a AutoCAD 2d (Lines/Arcs/Circles) ready for laser cutting?
Any help would be great!!!!
Many thanks in advance.
Darren
salariua
Have spoken too soon. Shoud have beeter read your question.
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
