Export Parts List using iLogic - I've broken some code
andrew_canfield
andrew_canfield
Hello
I used this
http://inventortrenches.blogspot.com/2011/06/ilogic-export-parts-list-with-options.html
& it works on the default template but if I change the drawing style (for a custom parts list) it breaks.
What line here refers to the style in use for the parts list?
'-------------Start of ilogic ------------------------------------------------
'get the path and name of the drawing file
path_and_name = ThisDoc.PathAndFileName(False) ' without extension
'define oDoc
oDoc = ThisDoc.Document
'specify the drawing sheet
oSheet = oDoc.Sheets("Sheet:1") ' sheet by name
'oSheet = oDoc.Sheets(1) ' first sheet
 ' say there is a Partslist on the sheet.
oPartslist = oSheet.PartsLists(1)
' create a new NameValueMap object
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
'specify an existing template file
'to use For formatting colors, fonts, etc
oOptions.Value("Template") = "C:\Temp\PartListExport.xls"
'specify the columns to export
oOptions.Value("ExportedColumns") = "QTY;PART NUMBER;DESCRIPTION"
'specify the start cell
oOptions.Value("StartingCell") = "A3"
'specify the XLS tab name
'here the file name is used
oOptions.Value("TableName") = ThisDoc.FileName(False) 'without extension
'choose to include the parts list title row
'in this example "Ye Old List of Parts" is written to the StartingCell
oOptions.Value("IncludeTitle") = True
'choose to autofit the column width in the xls file
oOptions.Value("AutoFitColumnWidth") = True
' export the Partslist to Excel with options
oPartslist.Export(path_and_name & ".xls", _
PartsListFileFormatEnum.kMicrosoftExcel, oOptions)
'-------------End of ilogic ------------------------------------------------
WCrihfield
This line is specifying an excel template file to reference for style:
while this line is specifying the output file:
oPartslist.Export(path_and_name & ".xls", PartsListFileFormatEnum.kMicrosoftExcel, oOptions)
Is that what you were asking about?
Wesley Crihfield
(Not an Autodesk Employee)
andrew_canfield
Exporting the parts list from the template in use (not a test one) appears to have fixed the issue 🙂
andrew_canfield
a snag..
this did export the parts list to the same folder as the .idw, I'm trying to change this destination to the users desktop (code copied from a different rule).
The file name appears to be different in the error message to the ilogic message box..
the file is called "Parts List c.xlsx" but the error calls the file "91B28100" (this name will change too).
'define oDoc
Dim oFolder As String = System.Environment.GetFolderPath(System.Environment.SpecialFolder.Desktop) & "\Part List"
If Not System.IO.Directory.Exists(oFolder) Then
    System.IO.Directory.CreateDirectory(oFolder)
End If
'path_and_name = ThisDoc.PathAndFileName(False) ' without extension
Fname = ThisDoc.FileName(False) 'without extension
path1 = (System.Environment.GetFolderPath(System.Environment.SpecialFolder.Desktop) & "\Parts List")
path_and_name = path1 & "\" & Fname  & ".xlsx"
'define oDoc
'oOptions.Value("Template") = "C:\Temp\PartListExport.xls"
oOptions.Value("Template") = "K:\02 Inventor\JFNL\2018\01_Design Data\iLogic\UI\PL2018.xlsx"
oOptions.Value("StartingCell") = "A1"
MessageBox.Show(path_and_name, "path_and_name")
oPartslist.Export(path_and_name, PartsListFileFormatEnum.kMicrosoftExcel, oOptions)
'MessageBox.Show(path_and_name, "path_and_name2")
Regards
Andrew
andrew_canfield
found a typo... Part List & Parts List..
jonathan.victor
I'm usinge the same code, and its runnig perfectly, but how can i get rid of that confirmation to overwrite the table name when the template already has a sheet with the same name?
