Export part document to 3d pdf with API in c#
manasi_patilESZTV
manasi_patilESZTV
The error occurs at line 31 when attempting to export a part document to a 3D PDF using the API in C#.
public void Export3DPdf()
            Inventor.Application InvApp = mApp;
            Inventor.ApplicationAddIn  PDFAddin = null ;
            foreach (ApplicationAddIn appAddin in mApp.ApplicationAddIns )
                if (appAddin.ClassIdString == "{3EE52B28-D6E0-4EA4-8AA6-C2A266DEBB88}")
                    PDFAddin =  appAddin;
                    break;
            dynamic pdfConvertor3d = PDFAddin.Automation;
            Document oDoc = mApp.ActiveDocument;
            // Create a NameValueMap object
            Inventor.NameValueMap oOptions = InvApp.TransientObjects.CreateNameValueMap();
            oOptions.Value["FileOutputLocation"] = @"c:\temp\3DPDF.pdf";
            oOptions.Value["ExportAllProperties"] = true;
            oOptions.Value["GenerateAndAttachSTEPFile"] = true ;
            oOptions.Value["ExportTemplate"] = @"C:\Users\Public\Documents\Autodesk\Inventor 2025\Templates\Sample Part Template.pdf";
            oOptions.Value["VisualizationQuality"] = AccuracyEnum.kHigh;
            String[] sDesignViews = new string[] { "Front", "Top" };
            oOptions.Value["ExportDesignViewRepresentations"] = sDesignViews;
            pdfConvertor3d.Publish(oDoc, oOptions);
earl_cody
Hi @manasi_patilESZTV,
https://help.autodesk.com/view/INVNTOR/2024/ENU/?guid=ExportToPDF3D_Sample
I was able to get a 3D PDF working by changing/verifying a few things with the NameValueMap. I have Inventor 2024.
The export template file path was slightly different from the one given in the example documentation where the template 3D PDF is further housed in the "en-US" folder (at least on my machine):
//oOptions.Value["ExportTemplate"] = @"C:\Users\Public\Documents\Autodesk\Inventor 2024\Templates\Sample Part Template.pdf";
oOptions.Value["ExportTemplate"] = @"C:\Users\Public\Documents\Autodesk\Inventor 2024\Templates\en-US\Sample Part Template.pdf";
I also removed the "Master" view name from the namevaluemap and just kept the "View1". I see that you changed those names in your code so you already know, but in case someone else is looking here:
//String[] sDesignViews = new string[] { "Master", "View1" };
String[] sDesignViews = new string[] { "View1" };
I also dialed down the dialed down the quality and turned off generating a STEP file. Maybe you'll experience this too, but during the program run, Inventor switched to the background for about a minute, and then came back in the taskbar (I watched in the Windows Task Manager). Maybe these tweaks will help with the issue happening on your end.
Best,
Cody
All together C#:
static void Export3DPdf()
    Inventor.Application InvApp = //
    Inventor.ApplicationAddIn PDFAddin = null;
    foreach (ApplicationAddIn appAddin in InvApp.ApplicationAddIns)
            break;
    Document oDoc = InvApp.ActiveDocument;
    oOptions.Value["GenerateAndAttachSTEPFile"] = false;
    oOptions.Value["VisualizationQuality"] = AccuracyEnum.kLow;
jmacapagal2CD9H
