Add desription to parts in assembly
kresh.bell
kresh.bell
I use a very good iLogic for me. To assign a description ti parts in assembly environment.
Dim oOccurrence As ComponentOccurrence
msg = "Select a component (press ESC to exit)"
While True
	oOccurrence = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, msg)
	' If nothing gets selected then we're done
	If IsNothing(oOccurrence) Then Exit While
	oName = oOccurrence.Name
	ThisApplication.ActiveDocument.selectset.select(oOccurrence)
	oDesc = iProperties.Value(oName, "Project", "Description")
	oDesc = InputBox(oName & " Description", "iLogic", oDesc)
	If Not oDesc = Nothing Then iProperties.Value(oName, "Project", "Description") = oDesc
End While
Is it possible to edit that iLogic in a way that the toolbox has two fields. Existing field and one more field with description current assembly (also possible to change)?
Something like this
WCrihfield
Hi @kresh.bell.  Not with those simple dialogs.  And likely not even with an iLogic Form, because you would need to have interactive (event driven) control over the contents of one of those fields, which iLogic forms do not offer yet.  I believe you may need to design a vb.net based System.Windows.Forms.Form to accomplish this functionality.  That is usually done with Visual Studio, then copy most of that code over into an iLogic rule, within its own Class block of code.  It could be done without using Visual Studio, if you are familiar enough with the code involved, though.  Similar stuff has been done before entirely within iLogic rules.  When using a Windows form that you designed, you have almost total control of every aspect of the form by code, and can drive the contents and reactions with events that happen to the controls within that form.
Wesley Crihfield
(Not an Autodesk Employee)
kresh.bell
