Export idw drawings to autocad dwg files using ilogic rules
ysbaodnj
ysbaodnj
I want to export idw drawing to autocad dwg file.
on the idw drawing screen,  file -> export -> dwg
Is there a way to export to a dwg file using ilogic rules?
The source below is simply a rule to output to pdf.
Dim xlsFile As String = "C:\Temp\test\data.xlsx"
oPrintMgr
= ThisApplication.ActiveDocument.PrintManager pdfname = "filename" filePath = "C:\Temp\test"
oPrintMgr.Printer = "Microsoft Print to PDF" oPrintMgr.ColorMode = kPrintGrayScale oPrintMgr.Orientation = kLandscapeOrientation oPrintMgr.Scalemode = kCustomScale oPrintMgr.ScaleMode = PrintScaleModeEnum.kPrintBestFitScale oPrintMgr.PaperSize = kPaperSizeA4 oPrintMgr.PrintToFile(filePath + "\" + pdfname + ".pdf") Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument oDrawDoc.Close
petr.meduna
There is a sample program in Autodesk Inventor API Help that solves it (in Sample programs/Translators/Export). It just needs a little translation (delete set, subs name,...).
' Get the DWG translator Add-In.
Dim DWGAddIn As TranslatorAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC2-122E-11D5-8E91-0010B541CD80}")
'Set a reference to the active document (the document to be published).
Dim oDocument As Document = ThisApplication.ActiveDocument
Dim oContext As TranslationContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = kFileBrowseIOMechanism
' Create a NameValueMap object
Dim oOptions As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap
' Create a DataMedium object
Dim oDataMedium As DataMedium = ThisApplication.TransientObjects.CreateDataMedium
' Check whether the translator has 'SaveCopyAs' options
If DWGAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
	'your configuration ini file
	'Dim strIniFile As String = "C:\tempDWGOut.ini"
	' Create the name-value that specifies the ini file to use.
	'oOptions.Value("Export_Acad_IniFile") = strIniFile
End If
'Set the destination file name
oDataMedium.FileName = "c:\temp\test.dwg"
'Publish document.
Call DWGAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
ysbaodnj
thank you I solved it thanks 🙂
kwilson_design
When I try to run the code above, I'm getting this:
Error on line 29 in rule
The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
Kenny
If this post solved your issue please mark "Accept as Solution". It helps everyone...really!
Maxim-CADman77
You need ini file read more
Please vote for Inventor-Idea Text Search within Option Names
