Export Flat Pattern to DXF from assembly
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello everyone,
I've searched through this forum for a few options to export flat patterns to DXF, but those macros or iLogic rules didn't fit into my workflow. I tried to adapt them, but I lack the necessary knowledge.
Here's my workflow, and I hope someone could assist me:
- Scan all parts in the assembly and sub-assembly and export all flat patterns to DXF files.
- The files can be saved in the same path as the IPT file.
- Only boundaries and hole lines need to be exported; bending lines are not necessary.
If possible, I'd like the name of the DXF file to include:
- The name of the IPT file
- The total quantity placed (in both assembly and sub-assembly)
- The material
- The thickness
Thank you!
example of dxf file name
<name of the file IPT> - qnty - Material - Ticknees
24018-P-007 _ Side Reinforcement - 3x - Steel AS3678 GR 250 - 2mm
