Hi @inventor4578
You can pick this up from a loop of occurrences. See this article for the samples written in VBA
The name is displayed in the ilogic logger.
Code below in VB.NET for ilogic environment.
' Get the active assembly.
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
' Get the assembly component definition.
Dim oAsmDef As AssemblyComponentDefinition
oAsmDef = oAsmDoc.ComponentDefinition
' Get all of the leaf occurrences of the assembly.
Dim oLeafOccs As ComponentOccurrencesEnumerator
oLeafOccs = oAsmDef.Occurrences.AllLeafOccurrences
' Iterate through the occurrences and print the name.
Dim oOcc As ComponentOccurrence
For Each oOcc In oLeafOccs
Logger.Info(oOcc.Name)
Next
If this solved a problem, please click (accept) as solution.
Or if this helped you, please, click (like)
Regards
Alan
