Export BOM with Occurence Name (from assembly)
inventor4578
inventor4578
I know we have a lot of iLogic to make BOM from assembly, but i found nothing to get the Occurence Name of each component ?
inventor4578
Any idea for this BOM ? Thank you very much
A.Acheson
Hi @inventor4578
You can pick this up from a loop of occurrences. See this article for the samples written in VBA
The name is displayed in the ilogic logger.
Code below in VB.NET for ilogic environment.
' Get the active assembly.
    Dim oAsmDoc As AssemblyDocument
    oAsmDoc = ThisApplication.ActiveDocument
    ' Get the assembly component definition.
    Dim oAsmDef As AssemblyComponentDefinition
    oAsmDef = oAsmDoc.ComponentDefinition
    ' Get all of the leaf occurrences of the assembly.
    Dim oLeafOccs As ComponentOccurrencesEnumerator
    oLeafOccs = oAsmDef.Occurrences.AllLeafOccurrences
    ' Iterate through the occurrences and print the name.
    Dim oOcc As ComponentOccurrence
    For Each oOcc In oLeafOccs
        Logger.Info(oOcc.Name)
    Next
Regards
Alan
