Export and Import Materials Library with Excel
Message 1 of 26
 I would like to export and import my custom material library with Excel
I add materials to custom material library, (tensile strength, yield strength,...)
Accepted solutions (3)
Replies (25)
Message 21 of 26
diego_dorta
works fine.
thank you
Message 22 of 26
harri_parker
Hi, is this solution modifiable for import, as I have to import approximately 2000 materials. Therefore, I would like a quicker fix than manually start duplicating them and changing names, as that is the important part. To have correct name on drawing. Of course, the mechanical properties too for FEM calculations
Message 23 of 26
G60Dubs
Has there been any movment or development on this, or another method by which we can create a new matertial librarary en masse?   I will shortly have to create a new large material library.
Message 24 of 26
Terry_N
I have made this to import materials to the active library.  It works by copying the "Generic" material from the standard Inventor library then changing the properties to match a selected excel file. If the excel file isn't formatted correctly it will produce an example in the directory of the file you are running the rule from. I couldn't get the appearance to apply correctly so it just keeps the default appearance of "Generic". Maybe someone else can sort that out. If it finds a material already exists in the library it will skip it and add it to a txt doc report at the end. Let me know how it goes.
'iLogic rule to import a list of materials from excel to an existing material library.
'The defualt installed Inventor Material Library" needs to be avalible with  a material "Generic" in it for this to work.
'The defualt appreance that Generic had will be applied to all imported materials.
Imports System
Imports System.IO
Imports System.Windows.Forms
Imports Inventor
Sub Main
    ' Get the Inventor application and active material library
    Dim InvApp As Inventor.Application = ThisApplication
    Dim AML As AssetLibrary = InvApp.ActiveMaterialLibrary
    ' Show the current active library and prompt the user to confirm
    Dim confirmMessage As String = "The active material library is: " & AML.DisplayName & vbCrLf & vbCrLf & _
                                   "Do you want to upload materials to this library?"
    Dim confirmResult As DialogResult = MessageBox.Show(confirmMessage, "Confirm Active Library", MessageBoxButtons.YesNo, MessageBoxIcon.Question)
    If confirmResult <> DialogResult.Yes Then
        MessageBox.Show("Operation cancelled by user.", "Cancelled", MessageBoxButtons.OK, MessageBoxIcon.Information)
        Return
    ' Check if the library is writable
    If AML.IsReadOnly Then
        MessageBox.Show("The active material library is read-only. Please select a writable library and try again.", "Library Read-Only", MessageBoxButtons.OK, MessageBoxIcon.Warning)
        Return
    ' Prompt the user to select an Excel file
    Dim fileDialog As New OpenFileDialog()
    fileDialog.Filter = "Excel Files (*.xlsx; *.xls)|*.xlsx;*.xls"
    fileDialog.Title = "Select Excel File"
    If fileDialog.ShowDialog() <> DialogResult.OK Then
        MessageBox.Show("No file selected. Exiting rule.", "File Selection Cancelled", MessageBoxButtons.OK, MessageBoxIcon.Information)
        Return
    Dim excelFilePath As String = fileDialog.FileName
    ' Open Excel using CreateObject
    Dim excelApp As Object = CreateObject("Excel.Application")
    excelApp.Visible = False
    excelApp.DisplayAlerts = False
    ' Open the workbook and worksheet
    Dim workbook As Object = excelApp.Workbooks.Open(excelFilePath)
    Dim worksheet As Object = workbook.Sheets(1)
    ' Validate the Excel file headers
    Dim headers As New List(Of String) From {
        "Category Name", "Material Name", "Appearance Asset", "Density",
        "Thermal conductivity", "Specific heat", "Thermal expansion coefficient",
        "Young modulus", "Poisson ratio", "Shear modulus", "Minimum yield stress",
        "Minimum tensile strength", "Keywords"
    Dim isValidFile As Boolean = True
    For i As Integer = 1 To headers.Count
        If worksheet.Cells(1, i).Value <> headers(i - 1) Then
            isValidFile = False
            Exit For
    Next
    If Not isValidFile Then
        ' Create an example Excel file with the correct headers
        Dim exampleFilePath As String = System.IO.Path.Combine(System.IO.Path.GetDirectoryName(InvApp.ActiveDocument.FullFileName), "example_library.xlsx")
        Dim exampleWorkbook As Object = excelApp.Workbooks.Add()
        Dim exampleWorksheet As Object = exampleWorkbook.Sheets(1)
            exampleWorksheet.Cells(1, i).Value = headers(i - 1)
        Next
        exampleWorkbook.SaveAs(exampleFilePath)
        exampleWorkbook.Close()
        workbook.Close(False)
        excelApp.Quit()
        MessageBox.Show("The selected file is not formatted correctly. An example file has been created at: " & exampleFilePath & ". Please format your file and try again.", "Invalid File Format", MessageBoxButtons.OK, MessageBoxIcon.Warning)
        Return
    ' Read the Excel file and add materials to the library
    Dim duplicatesLog As New List(Of String)
    Dim rowCount As Integer = worksheet.UsedRange.Rows.Count
    ' Create a simple progress form without System.Drawing.Size
    Dim progressForm As New Form()
    progressForm.Text = "Processing Materials"
    progressForm.Width = 300
    progressForm.Height = 100
    Dim progressBar As New System.Windows.Forms.ProgressBar()
    progressBar.Minimum = 0
    progressBar.Maximum = rowCount - 1
    progressBar.Dock = DockStyle.Fill
    Dim cancelButton As New Button()
    cancelButton.Text = "Cancel"
    cancelButton.Dock = DockStyle.Bottom
    AddHandler cancelButton.Click, Sub(sender, E)
                                       progressForm.Close()
                                       excelApp.Quit()
                                       Return
                                   End Sub
    progressForm.Controls.Add(progressBar)
    progressForm.Controls.Add(cancelButton)
    progressForm.Show()
    ' Get the default Inventor library
    Dim defaultLibrary As AssetLibrary = InvApp.AssetLibraries.Item("Inventor Material Library")
    ' Find the "Generic" material in the default library
    Dim genericMaterial As MaterialAsset = Nothing
    For Each cat As AssetCategory In defaultLibrary.MaterialAssetCategories
        For Each ma As MaterialAsset In cat.Assets
            If ma.DisplayName = "Generic" Then
                genericMaterial = ma
                Exit For
        Next
        If genericMaterial IsNot Nothing Then Exit For
    Next
    If genericMaterial Is Nothing Then
        MessageBox.Show("The 'Generic' material could not be found in the default Inventor library.", "Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
        excelApp.Quit()
        Return
    ' Iterate through each row in the Excel file
    For i As Integer = 2 To rowCount
        ' Update the progress bar
        progressBar.Value = i - 1
        System.Windows.Forms.Application.DoEvents()
        ' Read values from the Excel file
        Dim categoryName As String = worksheet.Cells(i, 1).Value
        Dim materialName As String = worksheet.Cells(i, 2).Value
        Dim appearanceAsset As String = worksheet.Cells(i, 3).Value
        Dim density As Double = worksheet.Cells(i, 4).Value
        Dim thermalConductivity As Double = worksheet.Cells(i, 5).Value
        Dim specificHeat As Double = worksheet.Cells(i, 6).Value
        Dim thermalExpansionCoefficient As Double = worksheet.Cells(i, 7).Value
        Dim youngModulus As Double = worksheet.Cells(i, 8).Value
        Dim poissonRatio As Double = worksheet.Cells(i, 9).Value
        Dim shearModulus As Double = worksheet.Cells(i, 10).Value
        Dim minimumYieldStress As Double = worksheet.Cells(i, 11).Value
        Dim minimumTensileStrength As Double = worksheet.Cells(i, 12).Value
        Dim keywords As String = worksheet.Cells(i, 13).Value
        ' Check for duplicates in the material library
        Dim isDuplicate As Boolean = False
        For Each cat As AssetCategory In AML.MaterialAssetCategories
            If cat.DisplayName = categoryName Then
                    If ma.DisplayName = materialName Then
                        duplicatesLog.Add("Duplicate skipped: " & categoryName & " - " & materialName)
                        isDuplicate = True
                        Exit For
                Next
                Exit For
        Next
        ' If the material is not a duplicate, add it to the library
        If Not isDuplicate Then
            Try
				'copy inventor defualt generic to library
				genericMaterial.CopyTo(AML)
'                Rename the "Generic" material to create a new material name
				Dim newMaterial As MaterialAsset = AML.MaterialAssets.Item(genericMaterial.DisplayName)
				newMaterial.DisplayName = materialName
' Check if the category already exists
              Dim category As AssetCategory = Nothing
                For Each aCat As AssetCategory In AML.MaterialAssetCategories
                    If aCat.DisplayName = categoryName Then
                        category = aCat
                        Exit For
                Next
'                 If the category does Not exist, create it
					If category Is Nothing Then
                    ' create category
                    category = AML.MaterialAssetCategories.Add(categoryName.ToString, newMaterial)
'				Move the material to the correct category if it already exists.
				If newMaterial.CategoryName = "" Then
				newMaterial.CopyTo(AML.MaterialAssetCategories.Item(category.DisplayName.ToString))
				end if
'                ' Update the material properties from the Excel sheet
'                Try
'                    newMaterial.AppearanceAsset = AML.AppearanceAssets("Defualt")
'                Catch ex As Exception
'                    MessageBox.Show("Error updating AppearanceAsset for material: " & materialName & ". Error: " & ex.Message & vbCrLf & "Code Line: newMaterial.AppearanceAsset = AML.AppearanceAssets(appearanceAsset)", "Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
'                End Try
                Try
                    newMaterial.PhysicalPropertiesAsset.Item("structural_Density").Value = density
                    newMaterial.PhysicalPropertiesAsset.Item("structural_Thermal_conductivity").Value = thermalConductivity
                    newMaterial.PhysicalPropertiesAsset.Item("structural_Specific_heat").Value = specificHeat
                    newMaterial.PhysicalPropertiesAsset.Item("structural_Thermal_expansion_coefficient").Value = thermalExpansionCoefficient
                    newMaterial.PhysicalPropertiesAsset.Item("structural_Young_modulus").Value = youngModulus
                    newMaterial.PhysicalPropertiesAsset.Item("structural_Poisson_ratio").Value = poissonRatio
                    newMaterial.PhysicalPropertiesAsset.Item("structural_Shear_modulus").Value = shearModulus
                    newMaterial.PhysicalPropertiesAsset.Item("structural_Minimum_yield_stress").Value = minimumYieldStress
                    newMaterial.PhysicalPropertiesAsset.Item("structural_Minimum_tensile_strength").Value = minimumTensileStrength
                    newMaterial.Item("physmat_Keywords").Value = keywords
                    MessageBox.Show("Error updating propeties: " & materialName & ". Error: " & ex.Message , "Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
                End Try
                MessageBox.Show("Error adding material: " & materialName & ". Error: " & ex.Message, "Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
            End Try
    Next
    ' Close the progress form and clean up
    excelApp.Quit()
    ' Log duplicates to a text file
    If duplicatesLog.Count > 0 Then
        Dim logFilePath As String = System.IO.Path.Combine(System.IO.Path.GetDirectoryName(InvApp.ActiveDocument.FullFileName), "duplicates_log.txt")
        System.IO.File.WriteAllLines(logFilePath, duplicatesLog)
        MessageBox.Show("Duplicate materials were skipped. A log file has been created at: " & logFilePath, "Duplicates Logged", MessageBoxButtons.OK, MessageBoxIcon.Information)
    MessageBox.Show("Material import completed.", "Success", MessageBoxButtons.OK, MessageBoxIcon.Information)
End Sub
Message 25 of 26
Jelvin_
Just as a fyi, you have spelled default wrong in this line:
i corrected this line and it worked for me, and also added one for the physical asset and this code works very well.
Thank you.
Message 26 of 26
Terry_N
Hi Jelvin_
Its always the spelling, thanks for that. I had a play with is and got the appearances working. It will now check the available appearance libraries for an appearance with the same name then assign that to the new material.
'The default installed Inventor Material Library" needs to be avalible with  a material "Generic" in it for this to work.
'The default appreance that Generic had will be applied to all imported materials.
Imports System
Imports System.IO
Imports Inventor
Sub Main
        Return
        Return
        Return
            isValidFile = False
            Exit For
    Next
        Next
        excelApp.Quit()
        Return
                                       excelApp.Quit()
                                       Return
                                   End Sub
    progressForm.Show()
                Exit For
        Next
    Next
        excelApp.Quit()
        Return
                        isDuplicate = True
                        Exit For
                Next
                Exit For
        Next
            Try
                        category = aCat
                        Exit For
                Next
                    ' create category
				end if
			'look for appearnce in avalible  libraries
			Dim libAsset As Asset = Nothing
			    ' If not found, cycle through all appearance libraries
			    Dim assetLibs As AssetLibraries = ThisApplication.AssetLibraries
			For Each assetLib As AssetLibrary In assetLibs
					Try
						libAsset = assetLib.AppearanceAssets.Item(appearanceAsset)
			            Exit For
			        Catch
			' Continue to next library if not found
			        End Try
			    Next
			'Try make the new material appearance the one from the appearance library
			Try
				   newMaterial.AppearanceAsset = libAsset
			Catch
				Try
					'If doesn't work make it defualt
					newMaterial.AppearanceAsset = AML.AppearanceAssets("Default")
                End Try
			End Try
                Try
					'continue onto material properties
                End Try
            End Try
    Next
    excelApp.Quit()
End Sub
