We are currently experiencing an issue impacting some Autodesk Products and Services - please refer to the Autodesk Health Dashboard for updates.
Export all open drawings to PDF - All drawing saved as same
gmataleite
gmataleite
I created two external rules to export all open drawings to PDF, the first rule is only to run a main rule, where the export is made, but I'm having an issue. The only drawing exported is the one where I run the first rule, saved as different names.
For Each doc As Document In ThisApplication.Documents.VisibleDocuments
	If doc.DocumentType = DocumentTypeEnum.kDrawingDocumentObject Then
		iLogicVb.Automation.RunExternalRule(doc, "SavePDF")
	End If
Next
MessageBox.Show("All PDFs created", "Ready!", MessageBoxButtons.OK)
Sub Main()
	FileName = ThisDoc.FileName(True) 'with extension
	FileExtension = Right(FileName, 3)
	If FileExtension = "idw" Then
		Save_As_PDF
	Else If FileExtension = "dwg" Then
		Save_As_PDF
	Else
		ErrorMessage
	End If
End Sub
Sub Save_As_PDF
	oPath = ThisDoc.Path
	oFileName = ThisDoc.FileName(False)
	oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
	oDocument = ThisApplication.ActiveDocument
	oContext = ThisApplication.TransientObjects.CreateTranslationContext
	oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
	oOptions = ThisApplication.TransientObjects.CreateNameValueMap
	oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
	oRevNum = iProperties.Value("Project", "Revision Number")
	WorkspacePath = ThisDoc.WorkspacePath()													'Gets the workspace path
	WorkspacePathLength = Len(WorkspacePath)												'Gets the length of the workspace path string
	PathOnly = ThisDoc.Path																	'Gets just the path of the file
	DirectoryPath = Strings.Right(PathOnly, PathOnly.Length - WorkspacePathLength)			'Removes the workspace path from fullpath
	PDFPath = ThisDoc.Path & "\2D_PDF"								'Sets the directory that the pdf should be saved in
	PDFName = PDFPath & "\" & ThisDoc.FileName(False) & "_" & oRevNum & ".pdf"								'Saves the pdf in the desired location
	oDataMedium.FileName = PDFName
	oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
	If Not System.IO.Directory.Exists(PDFPath) Then											'checks to see if that directory exists, if not, it is created
		System.IO.Directory.CreateDirectory(PDFPath)
	End If
	'Check to see if the PDF already exists, if it does, ask if you want to overwrite it or not.
	If System.IO.File.Exists(PDFName) = True Then
		oAnswer = MsgBox("A PDF file with this name already exists." & vbCrLf &
		"Do you want to overwrite it with this new one?",vbYesNo + vbQuestion + vbDefaultButton2, "PDF ALREADY EXISTS")
		If oAnswer = vbNo Then Exit Sub
	End If
	oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
	'MessageBox.Show("PDF created","Message", MessageBoxButtons.OK)
End Sub
Sub ErrorMessage
	i = MessageBox.Show("This Is Not a drawing File. No PDF will be created.", "Create PDF", MessageBoxButtons.OK, MessageBoxIcon.Hand, MessageBoxDefaultButton.Button1)
End Sub
All files were create, but they're all the same.
I think there's some error in my code, but I couldn't figure out. Can anyone help me?
Thanks a lot.
JelteDeJong
In your 2e rule you use "ThisDoc" to get the document object. but this is always the active document. You need to pass the document object of the document that you want to export to the "Save_as_pdf function". Doing that between 2 rules is a bit difficult. Is there a reason why you dont want to combine these rules?
Jelte de Jong
Blog: hjalte.nl - github.com
gmataleite
There's none specifically reason, I already had the rule to export, after I created the rule to all for make easier my work.
I tried some others ilogic that I found here, but I couldn't do correctly.
I appreciate if you help me how to merge this two codes.
Curtis_Waguespack
Hi @gmataleite
Give this a try.
I hope this helps.
Curtis
Sub Main
			Call Save_As_PDF(doc)
		End If
	Next
End Sub
Sub Save_As_PDF(oDoc As Document)
	oPath = IO.Path.GetDirectoryName(oDoc.FullFileName)
	oFileName = IO.Path.GetFileNameWithoutExtension(oDoc.FullFileName)
	oRevNum = oDoc.PropertySets.Item(1).Item("Revision Number").Value
	PDFPath = oPath & "\2D_PDF"
	PDFName = PDFPath & "\" & oFileName & "_" & oRevNum & ".pdf"
	End If
		"Do you want to overwrite it with this new one?", vbYesNo + vbQuestion + vbDefaultButton2, "PDF ALREADY EXISTS")
	End If
	oPDFAddIn.SaveCopyAs(oDoc, oContext, oOptions, oDataMedium)
End Sub
gmataleite
It worked well!
Thanks a lot!
