Export all Model States to individual step files
HSI-Autodesk
HSI-Autodesk
We have part files with multiple model states. Like 20 each. Eacch time we update something across all states, i must regenerate the step files for each state. Instead of doing it manually, How can I go about using ilogic to make run a script to export each individual model state as a step file with the filename being the model state name to a chosen folder.
I looked though all the inventor add-ons, and couldn't find one that would do this, and looked searched this forum to see if anyone had done this before.
I found this forum where someone posted how to get a list of the model states and pick one to export, but I haven't been able to modify it to do my use case yet.
https://forums.autodesk.com/t5/inventor-programming-ilogic/selection-list-of-which-model-state-to-ex...
Any help is appreciated.
Thank you.
JelteDeJong
Try this:
Dim oSTEPTranslator As TranslatorAddIn = ThisApplication.ApplicationAddIns.ItemById("{90AF7F40-0C01-11D5-8E83-0010B541CD80}")
Dim doc As PartDocument = ThisDoc.Document
Dim def As PartComponentDefinition = doc.ComponentDefinition
Dim folderDialog As New System.Windows.Forms.FolderBrowserDialog()
folderDialog.SelectedPath = System.IO.Path.GetDirectoryName(doc.FullFileName) ' "c:\temp\"
folderDialog.ShowDialog()
Dim folder = folderDialog.SelectedPath
For Each modelState As ModelState In def.ModelStates
    ModelState.Activate()
    ' Get the STEP translator Add-In.
    Dim oContext As TranslationContext = ThisApplication.TransientObjects.CreateTranslationContext
    Dim oOptions As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap
    If oSTEPTranslator.HasSaveCopyAsOptions(ThisApplication.ActiveDocument, oContext, oOptions) Then
        ' Set application protocol.
        ' 2 = AP 203 - Configuration Controlled Design
        ' 3 = AP 214 - Automotive Design
        oOptions.Value("ApplicationProtocolType") = 3
        ' Other options...
        'oOptions.Value("Author") = ""
        'oOptions.Value("Authorization") = ""
        'oOptions.Value("Description") = ""
        'oOptions.Value("Organization") = ""
        oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
        Dim oData As DataMedium = ThisApplication.TransientObjects.CreateDataMedium
        oData.FileName = System.IO.Path.Combine(folder, ModelState.Name & ".stp")
        oSTEPTranslator.SaveCopyAs(ThisApplication.ActiveDocument, oContext, oOptions, oData)
    End If
Next
Jelte de Jong
Blog: hjalte.nl - github.com
Johnnytk36
Community Visitor
Community Visitor
I was wondering why I couldn't accept your solution. I was logged into my personal autodesk account and not the company. haha
Thanks again.
HSI-Autodesk
Thank You! This works perfect!
I didn't know where to start on this, and you gave me exactly what I wanted.
I made two changes, I am going to post here for other people.
I added the base document name to the exported filename path, and I added a line to got back to the primary model state after this export is done.
        ' Other options...
        oData.FileName = System.IO.Path.Combine(folder, ThisDoc.FileName(False) & " - " & ModelState.Name & ".stp")
    End If
Next
ThisDoc.ActiveModelState = ThisServer.LanguageTools.CurrentPrimaryModelStateString
