Explaining what ilogic can do.
I'd like some help in creating a list of simple ideas of what can be done with ilogic. Ideally real world examples of ilogic in use - the code can come later - just a list to inspire. Cheers MES
For a start:-
Save out a drawing as pdf when saving.
Resize the paper to suit the drawing view.
Rescale the drawing view to suit the paper.
Create a custome filter to supress parts in an assembly.
Resorting to writing to myself.
Killer ilogic application:
Reset the scale so a model will fit on the paper - useful when the model is an ipart/assy.i.e as the model size changes it will become too big to fit the sheet so rescale via ilogic.
l8r
Curtis_Waguespack
Hi MarkESmith,
Thanks for the recommendation.
I thought I'd add a link to a page with all of the posts related to iLogic:
http://inventortrenches.blogspot.com/search/label/Autodesk%20Inventor%20iLogic
Hopefully others will find these helpful.
Best of luck to you in all of your Inventor and iLogic pursuits,
Curtis
