Exit the AEC_Exchange:Environment
nooraldeen.saleem
nooraldeen.saleem
I am hoping that the answer to this is easy, but at the same time, I don't because I will be disappointed in myself that I have put so much time without finding it.
Well this is the problem.
Sub Main()
	'Enter the BIM Content environment
	ThisApplication.CommandManager.ControlDefinitions.Item("AEC_Exchange:Environment").Execute()
End Sub
 This code Enters The AEX_Exchange:Environment. But how do i Then Exit it?
Michael.Navara
Here is short sample how to switch into and exit from AEC Exchange environment without .Execute method
Sub Main
	Dim doc As Document = ThisDoc.Document
	Dim envMgr As EnvironmentManager = doc.EnvironmentManager
	'Get current environment
	Dim currEnv As Inventor.Environment
	Dim editTargetId As String
	envMgr.GetCurrentEnvironment(currEnv, editTargetId)
	Logger.Debug("{0} - {1}", currEnv.DisplayName, currEnv.InternalName)
	MsgBox("Switch to AEC Exchange environment")
	'Set specific environment
	Dim envInternalName = "AEC_Exchange:Environment"
	Dim aecExchangeEnv = ThisApplication.UserInterfaceManager.Environments(envInternalName)
	envMgr.SetCurrentEnvironment(aecExchangeEnv)
	MsgBox("Exit AEC Exchange")
	'Set base environment (Exit AEC)
	Dim baseEnv As Inventor.Environment = envMgr.BaseEnvironment
	envMgr.SetCurrentEnvironment(baseEnv)
End Sub
For more info see here
nooraldeen.saleem
Thank you. This worked perfectly
