change text style
change text style
keithc03GZXH6
change text style
keithc03GZXH6
could someone assist please
I need some code that will look at an Inventor Drawing sheet and find text that uses a style (A) and change / update the text to use style (B)
Andrii_Humeniuk
Hi @keithc03GZXH6 . This is code that copies the properties of one text style to another. You need to write the appropriate names for lines 4 and 5.
Dim oDDoc As DrawingDocument = ThisApplication.ActiveDocument
Dim oTM As TransactionManager = ThisApplication.TransactionManager
Dim oTS As TextStylesEnumerator = oDDoc.StylesManager.TextStyles
Dim sNameTextA As String = "Name text style A"
Dim sNameTextB As String = "Name text style B"
Dim oStyleA As TextStyle = oTS.Item(sNameTextA)
Dim oStyleB As TextStyle = oTS.Item(sNameTextB)
Dim newTM As Transaction = oTM.StartTransaction(oDDoc, "ChangeTextStyle")
If oStyleA.InUse Then
	oStyleA.Bold = oStyleB.Bold
	oStyleA.Color = oStyleB.Color
	oStyleA.Font = oStyleB.Font
	oStyleA.FontSize = oStyleB.FontSize
	oStyleA.HorizontalJustification = oStyleB.HorizontalJustification
	oStyleA.Italic = oStyleB.Italic
	oStyleA.LineSpacing = oStyleB.LineSpacing
	oStyleA.Rotation = oStyleB.Rotation
	oStyleA.Underline = oStyleB.Underline
	oStyleA.VerticalJustification = oStyleB.VerticalJustification
	oStyleA.WidthScale = oStyleB.WidthScale
newTM.End()
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
keithc03GZXH6
THANK YOU
This works for me
keithc03GZXH6
Andrii
the code below used to work by giving a list of the available styles but i would like to specify the style by name and not pick from a list
where / what would I change
Sub Main
	If ThisDoc.Document.DocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then
		MsgBox("A Drawing document must be active for this code to work. Exiting.", vbCritical, "")
		Exit Sub
	Dim oDDoc As DrawingDocument = ThisDoc.Document
	Dim oSMgr As DrawingStylesManager = oDDoc.StylesManager
	Dim oSSNames As New List(Of String)
	For Each oSS As DrawingStandardStyle In oSMgr.StandardStyles
		oSSNames.Add(oSS.Name)
	Next
	Dim oSSName As String = InputListBox("Choose Standard Style For Active Sheet", oSSNames)
	If oSSName = "" Then Exit Sub
	Dim oDSS As DrawingStandardStyle = oSMgr.StandardStyles.Item(oSSName)
	Dim oSheet As Sheet = oDDoc.ActiveSheet
	SetSheetStandardStyle(oSheet, oDSS)
	If oDDoc.RequiresUpdate Then oDDoc.Update2(True)
	'If oDDoc.Dirty Then oDDoc.Save
End Sub
Sub SetSheetStandardStyle(oSheet As Sheet, oDSS As DrawingStandardStyle)
	If IsNothing(oSheet) Or IsNothing(oDSS) Then Exit Sub
	Dim oDStyles As ObjectDefaultsStyle = oDSS.ActiveObjectDefaults
	Dim oDDims As DrawingDimensions = oSheet.DrawingDimensions
	Dim oGDims As GeneralDimensions = oDDims.GeneralDimensions
	For Each oGDim As GeneralDimension In oGDims : oGDim.Style = oDStyles.LinearDimensionStyle : Next
	Dim oODims As OrdinateDimensions = oDDims.OrdinateDimensions
	For Each oODim As OrdinateDimension In oODims : oODim.Style = oDStyles.OrdinateDimensionStyle : Next
	Dim oODSs As OrdinateDimensionSets = oDDims.OrdinateDimensionSets
	For Each oODS As OrdinateDimensionSet In oODSs : oODS.Style = oDStyles.OrdinateSetDimensionStyle : Next
	Dim oCDSs As ChainDimensionSets = oDDims.ChainDimensionSets
	For Each oCDS As ChainDimensionSet In oCDSs : oCDS.Style = oDStyles.ChainDimensionStyle : Next
	Dim oBDSs As BaselineDimensionSets = oDDims.BaselineDimensionSets
	For Each oBDS As BaselineDimensionSet In oBDSs : oBDS.Style = oDStyles.BaselineDimensionStyle : Next
	Dim oDNotes As DrawingNotes = oSheet.DrawingNotes
	Dim oCNs As ChamferNotes = oDNotes.ChamferNotes
	For Each oCN As ChamferNote In oCNs : oCN.DimensionStyle = oDStyles.ChamferNoteStyle : Next
	Dim oGNs As GeneralNotes = oDNotes.GeneralNotes
	For Each oGN As GeneralNote In oGNs : oGN.TextStyle = oDStyles.GeneralNoteStyle : Next
	Dim oHTNs As HoleThreadNotes = oDNotes.HoleThreadNotes
	For Each oHTN As HoleThreadNote In oHTNs : oHTN.Style = oDStyles.HoleNoteStyle : Next
	Dim oLNs As LeaderNotes = oDNotes.LeaderNotes
	For Each oLN As LeaderNote In oLNs : oLN.DimensionStyle = oDStyles.LeaderTextStyle : Next
	Dim oPNs As PunchNotes = oDNotes.PunchNotes
	For Each oPN As PunchNote In oPNs : oPN.DimensionStyle = oDStyles.PunchNoteStyle : Next
	oSheet.Update
End Sub
Andrii_Humeniuk
If you want to write a specific style in the code by name instead of selecting from a list, then you need to replace this code:
	Next
 with this:
Dim oSSName As String = "Name text style A"
The rule will look like this:
Sub Main
		Exit Sub
End Sub
	oSheet.Update
End Sub
