Execute code on all open drawings (idw)
tobias
tobias
I have a lot of drawings where I need to change the TitleBlock and I als need to delete a few old TitleBlocks from the drawing.
To change the TitleBlock for a single idw I have the following working code but it needs to through all open idw's.
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
Dim sSheetName As String
For Each oSheet In oDoc.Sheets
oSheet.Activate
'If TitleBlock is A, switch to B
If ActiveSheet.TitleBlock="A" Then
ActiveSheet.TitleBlock = "B"
Else
'do nothing
Next
Tobias
The Netherlands
Inventor Pro 2026, Vault Pro 2026, AutoCad Electrical 2026.
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Andrii_Humeniuk
Hi @tobias . To access documents that are already open, you need to use the Inventor.Documents method. Example:
Dim oInvApp As Inventor.Application = ThisApplication
For Each oDDoc As DrawingDocument In oInvApp.Documents.OfType(Of DrawingDocument)
	For Each oSheet As Sheet In oDDoc.Sheets
		oSheet.Activate()
		Else
		'do nothing
	Next
Next
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
tobias
Thanks @Andrii_Humeniuk,
But it still does only the current drawing, not all open drawings.
Tobias
The Netherlands
Andrii_Humeniuk
Sorry, you are right, you need to add the oDDoc.Activate() method. See the example below.
	oDDoc.Activate()
		oSheet.Activate()
		Else
		'do nothing
	Next
Next
tobias
Hi @Andrii_Humeniuk,
It now goes through all open drawings 👍
but it only executes the TitleBlock change on the first open drawing.
Thanks for your help!
Tobias
The Netherlands
Andrii_Humeniuk
Then your code should look like this:
	oDDoc.Activate()
	Dim oBlock As TitleBlockDefinition
	oBlock = TryCast(oDDoc.TitleBlockDefinitions("B"), TitleBlockDefinition)
	If oBlock Is Nothing Then
		MessageBox.Show("Failed to get TitleBlock in active document.", "Error")
		Continue For
		oSheet.Activate()
		If oSheet.TitleBlock.Name = "A" Then
			oSheet.TitleBlock.Delete()
			oSheet.AddTitleBlock(oBlock)
		Else
		'do nothing
	Next
Next
tobias
I'm impressed. Thank you so much, works great!
Tobias
The Netherlands
