ContentCenter edit through InventorServer
m_baczewski
m_baczewski
Hi, I have a problem. I'm trying to integrate Content Center with an ERP system. I wasn't sure if I could edit the Content Center database from the application level. I managed to do it by writing this test code:
Dim oInvApp As Inventor.Application = ThisApplication
Dim oContentKsztal As ContentTreeViewNode
Dim oContentProfile As ContentTreeViewNode
For Each oContentTree As ContentTreeViewNode In oInvApp.ContentCenter.TreeViewTopNode.ChildNodes
	If oContentTree.DisplayName = "Kształtowniki konstrukcyjne"
		oContentKsztal = oContentTree
Next
For Each item1 As ContentTreeViewNode In oContentKsztal.ChildNodes
	If item1.DisplayName = "Rury kwadratowe/prostokątne"
		oContentProfile = item1
Next
Dim profileStalowe As ContentFamily
For Each item3 As ContentFamily In oContentProfile.Families
	If item3.DisplayName = "KRATKI PROFILE STALOWE S235JRH"
		profileStalowe = item3
Next
Dim listParam As List(Of String) = New List(Of String) From {"32","54", "4", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "S235JR", "", "", "", "", ""}
profileStalowe.TableRows.Add(listParam.ToArray(),profileStalowe.TableRows.Count+1)
profileStalowe.Save
When I try to transfer this to Vault as a job processor task, where I'm using Inventor.Server, I unfortunately get an unspecified error. I cant define ContentCenter object.
 private void mTestMethod(IJobProcessorServices context, IJob job)
            InventorServerObject mInv = context.InventorObject as InventorServerObject;
            DesignProject designProject = mInv.DesignProjectManager.DesignProjects.AddExisting("C:\\xxxx\\xxx.ipj");
            designProject.Activate();
            ContentCenter CC = mInv.ContentCenter; // <--- error
 Has anyone ever encountered this problem or knows how to approach it?
m_baczewski
The error looks like this:
mInv.ContentCenter = mInv.ContentCenter: a System.Runtime.InteropServices.COMException is thrown.
And
It looks like it can't find some libraries. Has anyone encountered this issue?
