Excel Reading in ilogic code
Hi
i read two excel files in this code. I want for Rows 4 to 8, 5 parts created with their name A1, B1, V, A2, B2...
in the loop that i write it creates the first one but for second it fives me the error as below
Error in rule: Rule6, in document: A final.ipt
GoExcel: Could not match the column title: "ID"
first i input 3 for ID=3 and then i write 4 in the form but it give me that errorCapture.PNG
Sub Main()
ThisApplication.ActiveView.Fit
For J=3 To 7
GoExcel.Open("C:\Users\a.khakbaz\Desktop\Inventor\Linking to Pv elit\nozzle\Nozzles", "Sheet1")
VV=InputBox("Prompt", "id", "Default Entry",MessageBoxButtons.YesNo)
If VV=0 Then
Exit Sub
i = GoExcel.FindRow("C:\Users\a.khakbaz\Desktop\Inventor\Linking to Pv elit\nozzle\Nozzles", "Sheet1","ID", "=", VV)
N_ID= GoExcel.CurrentRowValue("nominalDiameter")
PIPE_THK=GoExcel.CurrentRowValue("actualThickness")
PRO_CEN=GoExcel.CurrentRowValue("outsideProjection")
PAD_OD=GoExcel.CurrentRowValue("padDiameter")
Dim sFilePath As String= ThisDoc.Path & "\"
ThisDoc.Save
doc = ThisDoc.Document
sNewName=GoExcel.CellValue("B" & i)
GoExcel.Close
GoExcel.Open("C:\Users\a.khakbaz\Desktop\Inventor\Linking to Pv elit\nozzle\WNFLG2", "Sheet1")
i = GoExcel.FindRow("C:\Users\a.khakbaz\Desktop\Inventor\Linking to Pv elit\nozzle\WNFLG2", "Sheet1","NPS","=",N_ID)
iLogicVb.UpdateWhenDone = True
O = GoExcel.CurrentRowValue("O")
C1 = GoExcel.CurrentRowValue("C")
CB = GoExcel.CurrentRowValue("CB")
CC= GoExcel.CurrentRowValue("CC")
R = GoExcel.CurrentRowValue("R")
No = GoExcel.CurrentRowValue("No")
G = GoExcel.CurrentRowValue("G")
D = GoExcel.CurrentRowValue("D")
X = GoExcel.CurrentRowValue("X")
A1 = GoExcel.CurrentRowValue("A")
Y1 = GoExcel.CurrentRowValue("Y1")
YY = GoExcel.CurrentRowValue("YY")
RA = GoExcel.CurrentRowValue("RA")
RuleParametersOutput()
GoExcel.Close
ThisDoc.Document.Update()
ThisDoc.Document.saveas(sFilePath & sNewName & ".ipt",True)
Next J
End Sub
HermJan.Otterman
could you attach/send the excel files also
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
could you please take a look at below link...
i send my question again and also my excel files are attached.
Now i just cant give drawing.
if have nay idea, i'm willing to read
thank you
http://forums.autodesk.com/t5/inventor-customization/excel-reading-in-ilogic-code/m-p/6065546/highli...
HermJan.Otterman
the problem is in the line :
sNewName As String = GoExcel.CellValue("B" & i)
if you remove that line it works
i'm not sure what it does..
(you have to restart invenor or have to save the xls after you get the error to get it going again)
Herm Jan
HermJan.Otterman
this is Rule 3, and now it works (with me)
I turned some things off, you can turn them on but I doubt if they do anything, but you can judge that better.
I changed the line for sNewName...
Sub Main()
kk_LineNumber=1
For counter = 1 To 10
'MsgBox(counter,,"test")
GoExcel.Open(ThisDoc.Path & "\" & "Nozzles.xlsx", "Sheet1")
GoExcel.FindRowStart = kk_LineNumber+1
LineNumber = GoExcel.FindRow("Nozzles.xlsx", "Sheet1", "RadialNozzle", "=", "true", "class", "=" ,150, "flangeType", "=", 0)
'MsgBox(LineNumber,,"test2")
If LineNumber<>-1 Then
kk_LineNumber = LineNumber
nominalDiameter = GoExcel.CurrentRowValue("nominalDiameter")
MessageBox.Show("aa = "  & nominalDiameter, "Title")
MessageBox.Show("kk = "  & kk_LineNumber, "Title")
'ThisDoc.Save'doc = ThisDoc.Document'Dim sNewName As String = GoExcel.CellValue("B" & i)
Dim sNewName As String = GoExcel.CurrentRowValue("description")
'MsgBox(sNewName)'GoExcel.Close'Next j'GoExcel.Open("C:\Users\Ali Khakbaz\Desktop\nozzle\WNFLG2.xlsx", "Sheet1")'i = GoExcel.FindRow("C:\Users\Ali Khakbaz\Desktop\nozzle\WNFLG2.xlsx", "Sheet1", "NPS", "=", aa)
LineNumber2 = GoExcel.FindRow(ThisDoc.Path & "\" & "WNFLG2.xlsx", "Sheet1", "NPS", "=", aa)
MessageBox.Show("Message"  & LineNumber2-1, "Title",MessageBoxButtons.OK)
Lenght=  GoExcel.CurrentRowValue("O")
GoExcel.Close
Next counter
End Sub
Herm Jan
thanks for your reply..
would you please take a look at the corrected code to give me your idea?
I correct code and I want to add drawing to this code but it did not work for me
i'm waiting for your answer
