Drawing problem with ilogic code
Message 1 of 1
I want to create parts and make just one  drawing file for all part with the below code. in the code my loop is suppressed to show you that this code even for one loop does not work...
Can anyone find the problem?
Format:HTML Format Version:1.0 StartHTML: 165 EndHTML: 24575 StartFragment: 314 EndFragment: 24543 StartSelection: 314 EndSelection: 314SyntaxEditor Code Snippet
Sub Main()
Imports Inventor.ViewOrientationTypeEnum
Imports Inventor.DrawingViewStyleEnum
Dim oDoc As Document = ThisDoc.Document
Dim oDrawingDoc As DrawingDocument
Dim xDoc As Document
Dim oSheet As Sheet
Dim oTG As TransientGeometry
Dim oView1 As DrawingView
Dim sFilePath As String = ThisDoc.Path & "\"
Dim sNewName As String
Dim oSaveName As String = sFilePath & ThisDoc.FileName(False) & ".idw"
GoExcel.Open(ThisDoc.Path & "\" & "Nozzles.xlsx", "Sheet1")
Dim kk As Double = 1
'For j = 1 To 10
    GoExcel.FindRowStart = kk+1
    Dim i As Double = GoExcel.FindRow(ThisDoc.Path & "\" & "Nozzles.xlsx", "Sheet1", "RadialNozzle", "=", "true","class","=",150,"flangeType","=",0)
    If i <> -1 Then
        kk = i
        Dim aa As Double = GoExcel.CurrentRowValue("nominalDiameter")
        oDoc.Save
        sNewName = GoExcel.CellValue("B" & i)
        i = GoExcel.FindRow(ThisDoc.Path & "\" & "WNFLG2.xlsx", "Sheet1", "NPS", "=", aa)
        Parameter("Lenght") = GoExcel.CurrentRowValue("O")
        RuleParametersOutput()
        ThisDoc.Document.Update()
        ThisDoc.Document.saveas(sFilePath & sNewName & ".ipt", True)
        xDoc = ThisApplication.Documents.Open(sFilePath & sNewName & ".ipt", False)
        iLogicVb.UpdateWhenDone = True
'        oDrawingDoc = ThisApplication.Documents.Add(kDrawingDocumentObject,"tt.idw",True)
        oDrawingDoc=ThisApplication.Documents.Open(sFilePath & "Test.idw", True)
        oSheet = oDrawingDoc.Sheets.Item(1)
        oPoint1 = ThisApplication.TransientGeometry.CreatePoint2d(5, 5)
        oView1 = oSheet.DrawingViews.AddBaseView(xDoc, _
            oPoint1, _
            1/1#, _
            kBottomViewOrientation, _
            kHiddenLineDrawingViewStyle)
'Next j
ThisApplication.ActiveView.Fit
End Sub
Replies (0)
