Excel parameter link breaks after update when project saved on server.
Hi all,
So I want to work off of a server and I was transferring my project templates to it.
This template consists off a excel file with a few parameters and a couple of parts/assemblies which use those linked parameters to change the part names and other properties and drawings which update depending on those properties.
So essentially everything links back to the excel file and when that file is updated I go into inventor, save the top level assembly which pushes an update to all the other parts.
This template works absolutely fine when everything was saved locally but now when it is on the server the link breaks as soon as the excel file is updated. The parameters turn yellow although the path to the file hasn't changed.
Is there any fix or work around? I could move those from a excel file into the top level assembly and just update them there but I have other Text parameters in that excel file that are linked through ilogic as you cannot link text parameters straight from an excel file which also need updating so it would be nice to have it all there.
Inventor 2022.1.1
Windows 10 Home 21H1
