Applying Cost To A Material
adam.mangan
adam.mangan
I was wondering is it possible to add a cost to a material, i know of the other solutions were you add cost to the iProperties of a part, this is not what i want. Im talking in terms of adding a cost to a finish, for example. If i want a powder coat finish, i would apply a cost to the material finish "powder coat" and then when i applied it to the product, it would give me an overall cost of using the finish "powder coat". Allowing me to know how much it would cost to use different finishes on the product.
Ive been made aware that this can only really be done via Ilogic, however i lack the experience to write something this complex. Could someone point me inn the right direction? I know i will have to first find the mass and then appearance or the part, from there use the cost of the finish and multiple by the overall mass?
Many thanks,
Re: Applying Cost To A Material - Autodesk Community - Inventor
JelteDeJong
I don't know a way to add cost to a material. Instead, you can save the data in an iLogic rule (or a separate file but that is not in this example). just add the material and cost to the top of the rule.
Public Class ThisRule
    Sub Main()
        Dim costs As New Dictionary(Of String, materialCost)
        ' Add material and csot here.
        ' costs.Add("[Material name]", New materialCost([Material cost (../Kg)], [Surface treatment cost (../Cm^2)]))
        costs.Add("Generic", New materialCost(10, 30))
        costs.Add("Brass, Soft Yellow", New materialCost(20, 0))
        Dim doc As PartDocument = ThisDoc.Document
        Dim materialName = doc.ActiveMaterial.DisplayName
        If (costs.ContainsKey(materialName)) Then
            ' mass is in Kg
            Dim mass = doc.ComponentDefinition.MassProperties.Mass
            ' area is in Cm^2
            Dim area = doc.ComponentDefinition.MassProperties.Area
            Dim cost As materialCost = costs.Item(materialName)
            Dim materialCost = mass * cost.Material
            Dim surfaceTreatmentCost = area * cost.SurfaceTreatment
            Dim totalCost = materialCost + surfaceTreatmentCost
            Dim txt = "Material: " & materialCost & System.Environment.NewLine
            txt = txt + "Surface treatment: " & surfaceTreatmentCost & System.Environment.NewLine
            txt = txt + "Total: " & totalCost
            MsgBox(txt)
        Else
            MsgBox("Unable to calculate cost for material: " & materialName)
    End Sub
End Class
Public Class materialCost
    Public Sub New(material As Double, surfaceTreatment As Double)
        Me.Material = material
        Me.SurfaceTreatment = surfaceTreatment
    End Sub
    Public Property Material As Double
    Public Property SurfaceTreatment As Double
End Class
Jelte de Jong
Blog: hjalte.nl - github.com
sun069099
能將值對應到iproperty中嗎
