Example of creating a dimension in a sheet from objects in an assembly
oransen
Message 1 of 13
oransen
I have an assembly, tube with some other components attached to it. I'd like to add tube diameter and length dimensions to the sheet.
I can't find an example of how to do this. The examples I've found seem to start with know objects and use get_Item(1).
So is there an example of creating a dimension in a sheet from objects in an assembly?
I need a complete worked example because my knowledge is so fragmentary I feel as if I'm falling apart:
CreateGeometryIntent,  GeometryIntent, DrawingCurves, EdgeProxy/FaceProxy and so on.
Replies (12)
Message 2 of 13
Balaji_Ram
Hi Owen,
It is possible to choose which of the dimensional constraints get shown in a view using the Retrieve method.
This forum post should provide a code snippet to use that method.
http://forums.autodesk.com/t5/inventor-customization/retrieve-slected-dimension-in-view-with-vba/m-p...
Balaji
Balaji
Developer Technical Services
Autodesk Developer Network
Message 3 of 13
oransen
This is not exactly what I need.
Is there no tech article which explains the complete background and details of creating dimensions in an IDW from an IAM? Preferably with diagrams...?
Message 4 of 13
Balaji_Ram
Not that i am aware of.
When you say "add tube diameter and length dimensions to the sheet" I had interpreted your query as
retrieving the model dimensions which already exist in the assembly to show up in a view inside a sheet.
This is similar to using the "Retrieve dimensions" from the context menu in Inventor UI and then use
"Select dimensions" to only retain the ones that we need.
If you can clarify more on exactly what you are trying, I will try and find out if there is any information on that topic.
Balaji
Balaji
Message 5 of 13
oransen
There are actually two problems, but for this post lets stick to one.
I'm now able to use GetRetrievableDimensions to get an object collection validly. My next specific question:
How I add selected dimensions into the actual IDW drawing file?
    hRes = pGenDims->GetRetrievableDimensions (pThisView,gkvarEmpty,&pObjCollection) ;
    if (FAILED (hRes)) {
         gLogger.Printf (ekErrMsg,"Could not get ret dims") ;
    // So nowI have the object collection, how do I add...
    // them into the DrawingDocument?
Message 6 of 13
Balaji_Ram
Hi Owen,
I am working on this and will get back to you.
Retrieving all the dimensions is straight forward and this should work, but i will need to check on the second parameter to retrieve only a few of the retrievable dimensions.
				CComPtr<GeneralDimensionsEnumerator> pGenDimsEnum;
				hr = pGenDimensions->Retrieve(pDrawingView, CComVariant(), &pGenDimsEnum);
Balaji
Balaji
Message 7 of 13
oransen
Many thanks! I await with baited breath and anxious eyes!
Message 8 of 13
Balaji_Ram
Hi Owen,
Here is a code snippet to retrieve only a few of the retrievable dimensions
// Retrieve only a few of the retrievable dimensions
CComPtr<ObjectCollection> pObjCollection;
hr = pInvApp->TransientObjects->CreateObjectCollection(CComVariant(), &pObjCollection);
IDispatchPtr pDim;
hr = pObjColl->get_Item(_variant_t(1), &pDim);
pObjCollection->Add(pDim);
CComPtr<GeneralDimensionsEnumerator> pGenDimsEnum1;
hr = pGenDimensions->Retrieve(pDrawingView, CComVariant(pObjCollection), &pGenDimsEnum1);
Balaji
Balaji
Message 9 of 13
oransen
Thanks, that answers part of my original question:
Is there an example of adding them into the IDW file?
Message 10 of 13
Balaji_Ram
Hi Owen,
Do you mean creating a new drawing document and inserting a base view in it ?
http://adndevblog.typepad.com/manufacturing/2012/06/creating-drawing-views-via-the-inventor-api.html
After the base view has been inserted, the code to retrieve a few of the retrievable dimensions should work.
Balaji
Balaji
Message 11 of 13
oransen
I'm not at that computer at the moment... 😞
So you mean that Retrieval actually places the dims in the IDW? I'll let you know more tomorrow when I can experimnt. In the meantime thanks for your help.
Message 12 of 13
Balaji_Ram
No problem, please let me know after you get a chance to try it.
Yes, it does.
Please try running the code with a drawing document as active and the view should show up that dimension.
Balaji
Balaji
Message 13 of 13
oransen
Yep! That did it, thanks!
