Example code for a rectangular pattern of parts (occurrences?) in an assembly?
oransen
oransen
Hello All,
Is there any example code for a rectangular pattern of parts (occurrences?) in an assembly?
I've looked around but can't find one.
Imagine I have a Part in an Assembly, how to I programatically create an array of these parts?
TIA
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @oransen,
Try the following sample VBA code with attached assembly file.
Sub Main()
    Dim oDoc As AssemblyDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oDef As AssemblyComponentDefinition
    Set oDef = oDoc.ComponentDefinition
    Dim objColl As ObjectCollection
    Set objColl = ThisApplication.TransientObjects.CreateObjectCollection
    Call objColl.Add(oDef.Occurrences.Item(2))
    Dim oPattern As RectangularOccurrencePattern
    Set oPattern = oDef.OccurrencePatterns.AddRectangularPattern(objColl, oDef.WorkAxes.Item(3), False, "10 mm", 3)
End Sub
Please feel free to contact if there is any doubt.
If solves problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
oransen
While you were doing that in VB, for which many thanks, I wrote this in C++:
bool CreateYArrayOfParts (CComPtr<ComponentOccurrences> pOccurrencesList, // The occurrences in the assembly
                          CComPtr<AssemblyComponentDefinition> pCctsAssemblyCompDef,   // def of the assembly
                          CComPtr<ComponentOccurrence> pObjOcc,
                          const double kDeltaYMm,
                          const UINT ikCount)
    CComPtr<OccurrencePatterns> pOccPatterns ;
    pOccPatterns = pCctsAssemblyCompDef->GetOccurrencePatterns();
    if (pOccPatterns == nullptr) {
        gLogger.Printf(ekErrMsg, "GetOccurrencePatterns failed");
        return false;
    CComPtr<TransientObjects> pTransientObjects = theApp.GetTransientObjectsPtr() ;
    CComVariant varObjEnumerator;
    CComPtr<ObjectCollection> pObjectCollection;
    HRESULT hRes = pTransientObjects->CreateObjectCollection(varObjEnumerator, &pObjectCollection);
    if (FAILED(hRes)) {
        gLogger.Printf(ekErrMsg, "CreateObjectCollection failed");
        return false;
    // Add the part which is the basis to the pattern...
    hRes = pObjectCollection->Add (pObjOcc) ;
    if (FAILED(hRes)) {
        gLogger.Printf(ekErrMsg, "Add to ObjectCollection failed");
        return false;
    // Get hold of the y axis...
    CComPtr<WorkAxis> pYWorkAxis ;
    GetAsmWorkAxisByName (pYWorkAxis,L"Y Axis",pCctsAssemblyCompDef) ;
    if (FAILED(hRes)) {
        gLogger.Printf(ekErrMsg, "Could not get assembly y axis");
        return false;
    pOccPatterns->AddRectangularPattern(pObjectCollection,
                                        _variant_t((IDispatch *)pYWorkAxis),
                                        VARIANT_FALSE,
                                        CComVariant(kDeltaYMm/10.0), //ColumnOffset As Variant,
                                        CComVariant(ikCount), // ColumnCount As Variant,
                                        CComVariant(), // [RowEntity] As Variant,
                                        VARIANT_TRUE, // [RowEntityNaturalDirection] As Boolean,
                                        CComVariant(0.0),// [RowOffset] As Variant,
                                        CComVariant(1)); //  [RowCount] As Variant)
    return (hRes == S_OK) ;
...so our readers willl have two examples!  🙂
niranjan934
I need to pattern an existing component pattern which you shown above image 2 . I need to pattern image 2 with visual basic
oransen
Ah, sorry, I don't know how to do that, I've never needed it.  😞
