Error when saving new part file in API
cstephens58F4Q
cstephens58F4Q
Any ideas on fixing the error code im getting below when running this portion of code. Im trying to save as the part file i just created to a previously set directory.  Here is the line the error being created on and below that is the error im getting.
oDoc.SaveFileAs(oPath & loc)
error:
System.MissingMemberException: 'Public member 'SaveFileAs' on type '_DocumentClass' not found.'
Issue area:
    Public Sub CreateStandardPart(x_length As Double, y_length As Double, z_length As Double, loc As String, oPath As String)
        MsgBox("here with x length = " & x_length)
        'Create a new part with your desired part template
        'Dim oApp As Class = g_inventorApplication
        Dim oProjectMgr As DesignProjectManager = g_inventorApplication.DesignProjectManager
        Dim oProject As DesignProject
        oProject = oProjectMgr.ActiveDesignProject
        Dim oTemplatesPath As String
        oTemplatesPath = oProject.TemplatesPath
        Dim oDoc As PartDocument = g_inventorApplication.Documents.Add(DocumentTypeEnum.kPartDocumentObject, oTemplatesPath & "/English/OC Standard.ipt", True)
        oDoc.Activate()
    End Sub
Here is how I am calling out oPath:
SaveFileDialog1.Filter = "Assembly|*.iam"
        SaveFileDialog1.InitialDirectory = "C:\Temp"
        SaveFileDialog1.Title = "Save Melter Model"
        SaveFileDialog1.ShowDialog()
        If SaveFileDialog1.FileName IsNot "" Then
            SaveFileDialog1.OpenFile()
            oFile = SaveFileDialog1.FileName
        End If
        ''Sets directory for future use
        Dim oPath_ As String = oFile
        Dim oPat As Integer = InStrRev(oPath_, "\")
        Dim oPath As String = Mid(oPath_, 1, oPat)
A.Acheson
First think I notice. How are you bringing in "g_inventorApplication" into the sub routine "CreateStandardPart"
Have you set the inventor application object earlier?
Also I don't think  "SaveAsFile" method exists, it should be
Syntax
Document.SaveAsFileName As String, SaveCopyAs As Boolean )
oDoc.SaveAs(oPath & loc)
Regards
Alan
