Error 'parameter is incorrect' when replacing a subassembly
jberns-newell
jberns-newell
Community,
I am creating an assembly with a configurable subassembly.
The top-level assembly does not initially contain the subassembly.
After making choices, the user clicks the button on the form to run the rule (place the subassembly).
The initial run successfully places the subassembly.
The second run fails.
The rule looks for the existence of the subassembly. If found, delete from top-level assembly.
If a local file exists, it is deleted too.
During the second run, this error occurs:
The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
Here is the partial code. Error occurs on line 24 in the code below
		' Normalized name
		sNormalizedName = "Return Rails"
		If ComponentExists(ThisApplication.ActiveDocument, sNormalizedName) Then
			' Delete component
			Components.Delete(sNormalizedName)
		''' Return Rails ---------------------------------------------------------------------------
		' Component name
		sCompName = "\\eng\Inventor_Data\Templates\NMC_ASSEMBLY.iam"
		' Delete any local file
		If System.IO.Directory.Exists(sWorkspaceTempPath) AndAlso _
			System.IO.File.Exists(sWorkspaceTempPath & sNormalizedName & ".iam") Then
			System.IO.File.Delete(sWorkspaceTempPath & sNormalizedName & ".iam")
		' Create component from template
		Dim oReturnRailDoc As AssemblyDocument = ThisApplication.Documents.Add( _
			kAssemblyDocumentObject, _
			sCompName,
			False
		' Default filename to use when saved
		oReturnRailDoc.FullFileName = sWorkspaceTempPath & sNormalizedName & ".iam"
		''' E R R O R    O C C U R S   O N   L I N E   A B O V E   U P O N   S E C O N D   R U N
		' Add the occurrence
		Dim oReturnRailOcc As ComponentOccurrence = oAsmCompDef.Occurrences.Add(oReturnRailDoc.FullDocumentName, oMatrix)
		' Browser name
		oReturnRailOcc.Name = sNormalizedName
		' Not grounded
		oReturnRailOcc.Grounded = False
		' Constraints
		Constraints.AddFlush("ReturnRail_YZ-Assy_YZ", "", "YZ Plane", sNormalizedName, "YZ Plane")
		Constraints.AddFlush("ReturnRail_XZ-Assy_XZ", "", "XZ Plane", sNormalizedName, "XZ Plane")
		Constraints.AddFlush("ReturnRail_XY-Assy_XY", "", "XY Plane", sNormalizedName, "XY Plane")
		iProperties.Value(sNormalizedName, "Custom", "SortPriority") = "6"
		oReturnRailDoc.Close(True)
		oReturnRailDoc.ReleaseReference
Since it works the first time, I know the parameters are valid. After I delete, I suspect the file is lingering in memory, which causes the error on second run.
I welcome any insight and suggestion to correct the issue.
Jerry
JelteDeJong
It surprised me that setting a file name as you do on line 24 worked at all. Why don't you save the file with the correct file name? I would change line 24 into this:
oReturnRailDoc.SaveAs(sWorkspaceTempPath & sNormalizedName & ".iam", False)
Jelte de Jong
Blog: hjalte.nl - github.com
JBerns
@JelteDeJong (Jelte),
I did not want to perform a SaveAs yet during the subassembly update, since the design may still be changing.
My code is based on an example from @JhoelForshav :
https://forums.autodesk.com/t5/inventor-programming-ilogic/how-to-create-a-new-component-in-an-assem...
Upon reviewing my code, I found my mistake. After deleting the subassembly, I forgot to close all invisible documents. This solution was also provided by Jhoel.
https://forums.autodesk.com/t5/inventor-programming-ilogic/removing-components-from-quot-internal-qu...
' Normalized name
   ' Delete component
   ' Close invisible docs
   ThisApplication.Documents.CloseAll(True)
Code appears to be working now as expected. Thanks all for your contributions.
Jerry
CAD Administrator
Using AutoCAD & Inventor 2025
Autodesk Certified Instructor
Autodesk Inventor Certified Professional
Autodesk AutoCAD Certified Professional
