Balloon position(From the view)
leebrg
leebrg
I want to place the part number symbol at the bottom of the view in the drawing. The part number symbol is drawn manually, and I am writing a code to move the position of the drawn part number symbol. I want to place the part number symbol at a certain distance from the bottom border of the view. I want to place it at the bottom using the view, but there are only top and left methods. Is there another way?
I tried the code below but it wasn't what I wanted.
Dim Sheet_1 = ThisDrawing.Sheets.ItemByName("시트:1")
Dim oView1 As DrawingView = Sheet_1.View("BaseView1").View
Dim VIEW1 = Sheet_1.DrawingViews.ItemByName("BaseView1")
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
Dim Balloon1 As Balloon = oSheet.Balloons.Item(1)
Dim Balloon2 As Balloon = oSheet.Balloons.Item(2)
Dim Balloon3 As Balloon = oSheet.Balloons.Item(3)
Dim Balloon4 As Balloon = oSheet.Balloons.Item(4)
Dim Balloon5 As Balloon = oSheet.Balloons.Item(5)
Dim oPosition1 As Point2d = oTG.CreatePoint2d(Balloon1.Position.X, (VIEW1.Height - (VIEW1.Height - VIEW1.Center.Y)*2) / 10)
Dim oPosition2 As Point2d = oTG.CreatePoint2d(Balloon2.Position.X, (VIEW1.Height - (VIEW1.Height - VIEW1.Center.Y)*2) / 10)
Dim oPosition3 As Point2d = oTG.CreatePoint2d(Balloon3.Position.X, (VIEW1.Height - (VIEW1.Height - VIEW1.Center.Y)*2) / 10)
Dim oPosition4 As Point2d = oTG.CreatePoint2d(Balloon4.Position.X, (VIEW1.Height - (VIEW1.Height - VIEW1.Center.Y)*2) / 10)
Dim oPosition5 As Point2d = oTG.CreatePoint2d(Balloon5.Position.X, (VIEW1.Height - (VIEW1.Height - VIEW1.Center.Y)*2) / 10)
Balloon1.Position = oPosition1
Balloon2.Position = oPosition2
Balloon3.Position = oPosition3
Balloon4.Position = oPosition4
Balloon5.Position = oPosition5
WCrihfield
Hi @leebrg.  If you want to specify the bottom edge of a DrawingView, just use:
DrawingView.Top - DrawingView.Height
Similarly, if you want to specify the right edge of a view, use:
DrawingView.Left + DrawingView.Width
Wesley Crihfield
(Not an Autodesk Employee)
cidhelp
Hello @leebrg ,
you can use this:
Dim oS As Sheet = ThisDrawing.ActiveSheet.NativeEntity
Dim oView As DrawingView = oS.DrawingViews(1)
YVal = oView.Top - oView.Height - 1 '10 mm underneath the bottom view border
Dim oBalloon As Balloon
Dim oPoint As Point2d
For i = 1 To 5
	oBalloon = oS.Balloons(i)
	oPt = oTG.CreatePoint2d(oBalloon.Position.X, YVal)
	oBalloon.Position = oPt
Next
