Error in Vb.net - copy of drawing
premysl.misun
premysl.misun
I have part of program in VB.net which I use for copy of drawing and replace part in it by another. This work correctly before some weeks, but now I have error message in picture. I do not know why. With Inventor 2019 I uninstall some old versions of Inventor.
Thank you for your help.
Here it is program:
Module KopirovatVykres
    Dim _invApp As Inventor.Application
    Dim _started As Boolean = False
    Public Sub Kopirovat()
        Try
            _invApp = Marshal.GetActiveObject("Inventor.Application")
        Catch ex As Exception
        End Try
        Dim soubor As Inventor.DrawingDocument = _invApp.ActiveDocument
        If (soubor Is Nothing) Then
            MsgBox("Otevři nějaký výkres!")
        Else
            Dim path As String = System.IO.Path.GetDirectoryName(soubor.FullFileName)
            Dim path2 As String = System.IO.Path.GetFileName(soubor.FullFileName)
            Dim apprentice As New Inventor.ApprenticeServerComponent()
            Dim oDoc As Inventor.ApprenticeServerDocument = apprentice.Open(path & "\" & path2)
            Dim myFileSaveAs As FileSaveAs = apprentice.FileSaveAs  'Save the file to a new name
            Dim vykres_name As String
            vykres_name = InputBox("Zadej nové číslo výkresu")
            If vykres_name = "" Then
                MsgBox("Nezadán žádný název výkresu!")
            Else
                myFileSaveAs.AddFileToSave(oDoc, path & "\" & vykres_name & ".idw")  'Uloží otevřený soubor výkresu s názvem kopie před
                myFileSaveAs.ExecuteSaveCopyAs()
            soubor.Close()
            Dim oDoc2 As Document
            oDoc2 = _invApp.Documents.Open(path & "\" & vykres_name & ".idw")
            oDoc2.File.ReferencedFileDescriptors(1).ReplaceReference(path & "\" & vykres_name & ".ipt")
            Dim oDrawDoc As DrawingDocument = _invApp.ActiveDocument
            oDrawDoc.Update()
            oDrawDoc.Save()
    End Sub
End Module
Mark.Lancaster
@premysl.misun
Please use the Inventor Customization forum for programming questions and issues.
https://forums.autodesk.com/t5/inventor-customization/bd-p/120
I will have the moderator relocate it there to better suit your needs.
Mark Lancaster
