auto resize idw views when model linked to spreadsheet changes size
MikeKovacik4928
Advisor Advisor
Message 1 of 8
MikeKovacik4928
I am trying to fit a view to the same size box no matter what
dimensions I give the model.
The dimension I will be changing is on the spreadsheet as
RES01ID and is currently 15355mm
I have scaled VIEW1 to fit onto the sheet at 1:35.
If I change the inner diameter of the reservoir to
a smaller figure say 12000mm I want the scale to automatically
change to a smaller value, so the view occupies the same space.
I have started an ilogic rule called "Resize view to fit sheet-test01"
I am guessing I can use the system snippets - drawing features
maybe a combination of some of the view snippets like
"View Height" "View Width" "View Scale" "View Set Center"
Can anybody guide me in the right direction
Michael Kovacik
2d & 3d Autocad and Inventor designer/draughtsman
Draughting/Designing (Manufacturing) (31 yrs)
-Drawing Board (3 yrs)
--Cad (28 yrs)
---Cadkey (4 yrs)
---AutoCAD 2d & 3d (16 yrs)
---Inventor (4 yrs)
---Autocad and Inventor Simultaneously (4 years)
---(and recently Autocad/Inventor Customisation)
Authorised Autocad & Inventor Professional
Authorised Autodesk Trainer
Higher Diploma Mechanical Engineering
Autodesk Product Design Suite Ultimate 2018
Autocad 2018, Inventor Pro 2018
(personal licensed copy)
Johannesburg, South Africa
(Impossible only means you haven't
found the solution yet)
Replies (7)
Message 2 of 8
MikeKovacik4928
Okay guys, I get the idea, no spoon feeding, learn for yourself, no body is going to write programs for you.
I couldn't agree more
I will figure this one out  myself
I am loading the self paced guide "My First Plug-in"
and will start learning the VBA language and, in future, post actual attempts and be more specific on my questions
Mike Kovacik
Message 3 of 8
dgreatice
try this:
1. Change model size
2. Open Drawing
3. Run rule
Dim oApp As Application
Dim oDoc As Document
Dim oDD As DrawingDocument
Dim oSht As Sheet
Dim oBV As DrawingView
Dim oLabel As DrawingViewLabel
Dim oPt As Point2d
Dim oTg As TransientGeometry
App = ThisApplication
oDoc = oApp.ActiveDocument
If oDoc.DocumentType = kDrawingDocumentObject Then
oDD = oDoc
oSht = oDD.ActiveSheet
oBV = oSht.DrawingViews.Item(1)
oLabel = oBV.Label
oPt = oLabel.Position
oTg = oApp.TransientGeometry
oBV.ScaleString = "1 : 1"
BaseWidth = 51.87
If Round(oBV.Width, 2) > BaseWidth Then
SetScale = Round(oBV.Width / BaseWidth, 0)
oBV.ScaleString = "1 : " & SetScale
oLabel.Position = oTg.CreatePoint2d(oBV.Position.X, (oBV.Position.Y - (oBV.Height / 2)))
Else
MsgBox "Only for Drawing Document Type!", vbCritical, "Warning"
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
Message 4 of 8
MikeKovacik4928
Thanks very much for the programme
I copied and pasted it -see jpeg below
Inventor Customisation Queries_002_Using Ilogic to resize views to fit sheet-009.jpg
However it does not work
It comes up with the following error messages
See jpegs inserted below
Inventor Customisation Queries_002_Using Ilogic to resize views to fit sheet-012.jpgInventor Customisation Queries_002_Using Ilogic to resize views to fit sheet-013.jpgNot too sure how to fix it, what those messages refers to.
I am running Inventor Pro 2018 by the way.
Mike
Message 5 of 8
MikeKovacik4928
In answer to autodesk's email
See jpeg below
This has not yet been solved
A illogic programme was kindly posted, but it did not work.
I have posted screenshots of what I did and the error messages I received.
Inventor Customisation Queries_002_Using Ilogic to resize views to fit sheet-014.jpglMike Kovacik
Message 6 of 8
dgreatice
Sorry for late respond.
Dim oSht As Sheet
Dim oPt As Point2d
oApp = ThisApplication
If oDoc.DocumentType = DocumentTypeEnum.kDrawingDocumentObject Then
oDD = oDoc
oLabel = oBV.Label
BaseWidth = 51.87
Else
MsgBox ("Only for Drawing Document Type!", vbCritical, "Warning")
Message 7 of 8
MikeKovacik4928
Thanks!
Works perfectly
Will use your program as a starting point to learn
Programming. Will be in touch over in future over the forum
with more specific questions about how your program works
Mike
Message 8 of 8
dgreatice
Great,
You can learn more in:
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-6FD7AA08-1E43-43FC-971B-5F20E56C8846
