error in running the ilogic
khanubaid1
khanubaid1
I had developed an ilogic to get the flat pattern dimensions in a specific format exported to excel sheet for all the open part files. But i am getting an error saying Excel cell not found (bad cell address?): "A-93"  i understand the error but i am not able to troubleshoot the same.
 Code is as below: Please some could help regarding this
Sub Main
ThisApplication.CommandManager.ControlDefinitions.Item("AppZoomallCmd").Execute
For Each oDoc As Document In ThisApplication.Documents
        If TypeOf oDoc Is PartDocument Then
            Dim partDoc As PartDocument = oDoc
            If partDoc.ComponentDefinition.Type <> ObjectTypeEnum.kSheetMetalComponentDefinitionObject Then
                'MsgBox("A sheet metal document must be open.")
                Continue For
            currentStyle = SheetMetal.GetActiveStyle()
					If currentStyle = ("ALUM#11") Then
						ABC = "12002EB5NF"
						XYZ = ") .125 AL"
					If currentStyle = ("STEEL#11") Then
						ABC = "10101ACS60"
						XYZ = ") 11GA ST"
					Dim oDoc1 As PartDocument
					oDoc1 = ThisApplication.ActiveDocument
					Dim oCompDef As SheetMetalComponentDefinition
					oCompDef = oDoc1.ComponentDefinition
					If oCompDef.HasFlatPattern = False Then
						oCompDef.Unfold
						oCompDef.FlatPattern.ExitEdit
					filename2 = ThisDoc.PathAndFileName(False)
					index11 = InStrRev(filename2, "\")
					ActiveFileName = Mid(filename2,index11+1)
					ActiveFileName2 = ActiveFileName.split(".")(0)
					ActiveFileName2Length = Len(ActiveFileName2)
					'index12 = InStrRev(ActiveFileName2,"H")
					'ActiveFileName3 = Left(ActiveFileName2, index12 - 1)
					index13 = InStrRev(ActiveFileName2,"H")
					PartName = Right(ActiveFileName2, ActiveFileName2Length - index13 + 1)
					index3 = InStrRev(filename2,"\")
					folderPath=Left(filename2,index3)
					Dim oPath As String = folderPath
					index5 = InStrRev(filename2,"\")
					fullFileName = Mid(filename2,index5+1)
					newFileName1 = fullFileName.split(".")(0)
					index4 = InStrRev(newFileName1,"H")
					newFileName = Left(newFileName1,index4-1)
					'define Excel Application object
					excelApp = CreateObject("Excel.Application")
					'set Excel to run visibly, change to false if you want to run it invisibly
					excelApp.Visible = False
					'suppress prompts (such as the compatibility checker)
					excelApp.DisplayAlerts = False
					'define the file to create/open
					myXLS_File = (oPath & newFileName & ".xlsx") ' "C:\Temp\FlatExtent.xlsx"
					'check for existing file
					If Not Dir(myXLS_File) <> "" Then
						'workbook does NOT exist, so create a new one
						excelWorkbook = excelApp.Workbooks.Add
						excelWorkbook.SaveAs (myXLS_File)
						'close the workbook and the Excel Application
						'uncomment if you want to close the xls file at the end
						excelWorkbook.Close
						excelApp.Quit
						excelApp = Nothing
					' Open excel
					Worksheet = myXLS_File
					Sheetno = ("Sheet1")
					GoExcel.Open(Worksheet, Sheetno)
					'If GoExcel.FindRow(myXLS_File,"Sheet1","ITEM",PartName) Then
					'	GoTo Notification
					'End If
					If String.IsNullOrEmpty(GoExcel.CellValue("A" & 1)) Then
						GoExcel.CellValue("A" & 1) = "ITEM"
						GoExcel.CellValue("B" & 1) = "SYM"
						GoExcel.CellValue("C" & 1) = "DESCRIPTION"
						GoExcel.CellValue("D" & 1) = "PART NUMBER"
					' Define Range
					RowStart = 3
					RowEnd = 100
					For count = RowStart To RowEnd
						' If it's blank count it
						If String.IsNullOrEmpty(GoExcel.CellValue("C" & count)) Then
							i = i + 1
					Next
					' Next empty row is max rows minus blank rows plus one
					oRow = RowEnd - i + 1
					oRow1 = oRow + 1
					GoExcel.CellValue("A" & oRow) = PartName
					GoExcel.CellValue("C" & oRow) = Round(SheetMetal.FlatExtentsLength,3) & " X " & Round(SheetMetal.FlatExtentsWidth,3) & " " & iProperties.Value("Custom", "Title Line 3")
					GoExcel.CellValue("C" & oRow1) = ("LXW " & Round(SheetMetal.FlatExtentsLength,3) & " X " & Round(SheetMetal.FlatExtentsWidth,3)& XYZ)
					GoExcel.CellValue("D" & oRow) = ABC
					'add a small delay between text field updates
			Next
					Threading.Thread.Sleep(2000) 'in ms
					GoExcel.Save
					GoExcel.Close
					'workbook exists, open it
					excelWorkbook = excelApp.Workbooks.Open(myXLS_File)
					ExcelSheet = ExcelWorkbook.Worksheets(1)
					'set all of the columns to autofit
					excelApp.Columns.AutoFit
					excelWorkbook.Save
					excelWorkbook.Close
					excelApp.Quit
					excelApp = Nothing
					GoExcel.Save
					GoExcel.Close
MsgBox("Flat Pattern Extents Copied !")
End Sub
A.Acheson
Your running the excel application and go excel in the same rule. It would be best to use one or the other. Otherwise you have lots of opening/closing using different methods resulting in more errors.
For excel application you can write to a cell using this
Worksheets("Sheet1").Range("A1").Value
Last row with empty cell in column using this formula. You can search standard excel vba methods in stackoverflow
Dim LastRow as Long
LastRow = Range("A" & Rows.Count).End(xlUp).Row + 1
Worksheets("Sheet1").Range("A" & LastRow).Value = "1234"
Regards
Alan
khanubaid1
thank you for the response.
Can you help with the below code. Actually the code runs but the it shows the same flat length extents for all the part instead of changing for part specific.
Dim oExcel As Object
Dim oBook As Object
Dim oSheet As Object
oExcel = CreateObject("Excel.Application")
oBook = oExcel.Workbooks.Add
oSheet = oBook.Worksheets(1)
oSheet.Cells(1, 1).Value = "Part Name"
oSheet.Cells(1, 2).Value = "Length"
oSheet.Cells(1, 3).Value = "Width"
                Continue For
		 Dim oFlat As FlatPattern = oDoc.ComponentDefinition.FlatPattern
    oSheet.Cells(oSheet.UsedRange.Rows.Count + 1, 1).Value = oDoc.DisplayName
    oSheet.Cells(oSheet.UsedRange.Rows.Count, 2).Value = Round(SheetMetal.FlatExtentsLength,3) & " X " & Round(SheetMetal.FlatExtentsWidth,3) & " " & iProperties.Value("Custom", "Title Line 3")
Next
oExcel.Visible = True
oBook.SaveAs("C:\Users\E0571268\Desktop\MVB\MVB Orders\2023\Jan\MLR0011380_C_006_Shop_02_10_Ship_02_24_TGW_UK\Flats\FlatPatternDimensions.xlsx")
A.Acheson
In this line your using an ilogic snippet that will target the first document you run the rule from but will not move to the next.
Just before this you get the flat pattern object but don't use it.
You can pick up the width and length property of this object. See help file here.
Syntax
FlatPattern.Length() As Double
Also your iproperty is an ilogic snippet and again linked  in this case is the first document.
iProperty from API Property sets .
oDoc.PropertySets.item(4).Item("Title Line 3").value
Regards
Alan
