Automatic scale drawing with iLogic
jgomis.ext
jgomis.ext
Hi everybody !
I'm working on a drawing that will change the scale of my views automatically with iLogic.
In a first time, I have found the limit height and limit width that I would like for my views.
For example for my view 1 I have a maximal height of 252 and a maximal width of 738.
So I would like to automatically change the scale, to have a view that fit well in the limits that I have define.
I would to create a code like this maybe but I'm not really good in codding :
For i from 1 to …
                If ActiveView1Width > LimitView1Width then
                               View1Scale = 1/i
                Else
                               Exit
                End if
End for
Is it possible ?
Thanks for every helps 🙂
WCrihfield
Hi @jgomis.ext.  Have a look at these two similar forum topics which were also about creating, scaling, orienting, & placing multiple views into drawings.  You might get some ideas from these previous discussions, and the solutions that were posted for them.
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/automaticly-create-a-drawing-from-a-...
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/ilogic-create-drawnings-of-all-parts...
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/creating-4-views/m-p/11156300
Wesley Crihfield
(Not an Autodesk Employee)
