error in PDF Ilogic snippet
Message 1 of 11
I have upgradet to inventor 2019, better late than never, and have encounter this small problem.
When i run my PDF ilogic it shows a error message that says  that i use the wrong pointer, and i dont know why
The ilogic should make a pdf of every drw sheet and store it in the workspace with the name: filename + sheet x.pdf
PDF snippet code is here:
oPath = ThisDoc.Path
oFileName = ThisDoc.FileName(False) 'without extension
oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _
("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oDocument = ThisApplication.ActiveDocument
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
'Define the drawing
Dim oDrawing As DrawingDocument
oDrawing = ThisDoc.Document
Dim oSheet As Sheet
Dim lPos As Long
Dim rPos As Long
Dim sLen As Long
Dim sSheetName As String
Dim iSheetNumber As Integer
'step through each drawing sheet
For Each oSheet In oDrawing.Sheets
'find the seperator in the sheet name:number
lPos = InStr(oSheet.Name, ":")
'find the number of characters in the sheet name
sLen = Len(oSheet.Name)
'find the sheet name
sSheetName = Left(oSheet.Name, lPos -1)
'find the sheet number
iSheetNumber = Right(oSheet.Name, sLen -lPos)
'set PDF Options
If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then
oOptions.Value("All_Color_AS_Black") = 1
oOptions.Value("Remove_Line_Weights") = 1
oOptions.Value("Vector_Resolution") = 400
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
oOptions.Value("Custom_Begin_Sheet") = iSheetNumber
oOptions.Value("Custom_End_Sheet") = iSheetNumber
'Set the PDF target file name
'oDataMedium.FileName = oFolder & "\" & oFileName & " " & sSheetName & " " & iSheetNumber  & ".pdf"
oDataMedium.FileName = oPath & "\" & oFileName & "-" & sSheetName & "-" & iSheetNumber  & ".pdf"
'Publish document
oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
Next
'------end of iLogic-------
Replies (10)
Message 2 of 11
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Please provide non confidential sample drawing document to test the iLogic code.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 3 of 11
JhoelForshav
Hi @Anonymous
oPDFAddin.HasSaveCopyAsOptions takes the document as first argument, not DataMedium.
This should work 🙂
'Define the drawing
Dim oSheet As Sheet
Dim lPos As Long
Dim rPos As Long
Dim sLen As Long
'set PDF Options
If oPDFAddIn.HasSaveCopyAsOptions(oDrawing, oContext, oOptions) Then
'Publish document
Next
Message 4 of 11
@JhoelForshav
So I should substitute oDataMedium with oDrawing  in the entire snippet.
Excuse for my ignorance. I build this several years ago from different snippets by trial and error as I have no programming experience.
BTW I am amazed that i got an answer, because Yesterday my post did dissappear, and the forum support couldnt find any trace of it 🙂
Message 5 of 11
JhoelForshav
Hi @Anonymous
No, only in this line:
It should be:
Like I did in the code I posted in my first reply 🙂
Message 6 of 11
I tried that, but it didnt work.
I have attached the error message and the info to it
Message 7 of 11
JhoelForshav
Message 8 of 11
Yes
Message 9 of 11
JhoelForshav
@Anonymous
I'm sorry, but did you really run this rule?
'Define the drawing
Dim oSheet As Sheet
Dim lPos As Long
Dim rPos As Long
Dim sLen As Long
'Set PDF Options
'Publish document
Next
Because the error message you attached is the error message you get if you don't replace oDataMedium with oDrawing in oPDFAddIn.HasSaveCopyAsOptions....
You could also run it like this...
'Define the drawing
Dim oSheet As Sheet
Dim lPos As Long
Dim rPos As Long
Dim sLen As Long
'Set PDF Options
'Publish document
Next
Message 10 of 11
That solved my problem.
I used you solution 2 without the
and the end if
Message 11 of 11
Thanks a lot. You were most helpfull
Tack så mycket
