Can't check .BOMStructure in current Inventor's Operation both Part's & Assembly's Documents
ngdnam88
ngdnam88
Hello Everyone,
I'm trying working on a simple iLogic Code:
Dim nDOC As Document = ThisApplication.ActiveDocument
MessageBox.Show(nDOC.ComponentDefinition.BOMStructure, "Checking?", MessageBoxButtons.OK, MessageBoxIcon.Information)
And a similar
Dim nDOC As Document = ThisDoc.Document
MessageBox.Show([Enum].GetName(GetType(Inventor.BOMStructureEnum), nDOC.ComponentDefinition.BOMStructure), "Checking?", MessageBoxButtons.OK, MessageBoxIcon.Information)
 My problem: When I open Inventor with new session, and working with an assembly - the ilogic code run in the correct result, but when I created a new part and run the rule - I got the problem!. Its also happened if I started with Part first and then created a new assembly (the rule only applied with the first document's type/Inventor's session)
I'm using Inventor 2018.3.8 Updated, I checked, the problem same for previous version of Inventor. with Version 2020, the Rule runs in the correctly!!!
Please, help me. I really posted: https://forums.autodesk.com/t5/inventor-customization/how-to-get-and-change-quot-default-bom-structu... . Thanks!
WCrihfield
Try using this code, and see if it makes any difference for you.
I tried this on a fresh new assembly document, and a fresh new part document, before saving or doing any thing else to the file, and it worked for me.
Dim oBOMSt As BOMStructureEnum = ThisApplication.ActiveDocument.ComponentDefinition.BOMStructure
MsgBox("BOM Structure Name = " & oBOMSt.ToString & vbCrLf & _
"BOM Structure Value = " & oBOMSt.GetHashCode , vbOKOnly + vbInformation, "BOM Structure")
Wesley Crihfield
(Not an Autodesk Employee)
ngdnam88
Thanks @WCrihfield
I still have same problem. The iLogic code is very good for Inventor 2019 and Up.
I think, it relative to version of Inventor and the Code
Is there any new syntax/way to definition?
