Error in creating view representation drawing.
shizahkhalid
shizahkhalid
Can someone please tell me what the error is in the following iLogic rule?
Sub Main()
Dim oActiveDoc As Document
oActiveDoc = ThisApplication.ActiveDocument
Dim oDrgDoc As DrawingDocument = ThisApplication.Documents.Add(kDrawingDocumentObject)
Dim oSheet As Sheet
oSheet = oDrgDoc.Sheets.Item(1)
oSheet.Name = oActiveDoc.DisplayName
Dim oPoint1 As Point2d
    oPoint1 = ThisApplication.TransientGeometry.CreatePoint2d((oSheet.Width / 1.5)+5, oSheet.Height/2)
Dim oView1 As DrawingView
    oView1 = oSheet.DrawingViews.AddBaseView(oActiveDoc, oPoint1, 1/5, kCurrentViewOrientation, kShadedDrawingViewStyle, "", "", "BRACING DETAIL")
End Sub
I am getting these errors:
Thank you.
Curtis_Waguespack
Hi @shizahkhalid, try this version
Dim oSheet As Sheet
Dim oViewOptions As NameValueMap
oViewOptions = ThisApplication.TransientObjects.CreateNameValueMap
oViewOptions.Add("DesignViewRepresentation", "BRACING DETAIL")
oViewOptions.Add("DesignViewAssociative", True)
oPoint1 = ThisApplication.TransientGeometry.CreatePoint2d((oSheet.Width / 1.5) + 5, oSheet.Height / 2)
oView1 = oSheet.DrawingViews.AddBaseView(oActiveDoc, oPoint1, 1 / 5,
	ViewOrientationTypeEnum.kCurrentViewOrientation,
	DrawingViewStyleEnum.kShadedDrawingViewStyle,,,oViewOptions)
Related link:
https://help.autodesk.com/view/INVNTOR/2025/ENU/?guid=DrawingViews_AddBaseView
