Error in code while running Event Triggers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Good day,
Since we migrated from Inventor 2018 to Inventor 2023 I get a strange error.
The bit of code shown a bit more down runs with the iLogic Event Trigger when the drawing is opened.
In 2018 all was fine but now I get the following error:
The strange thing is is that the code runs perfectly fine when I run it manually....
Here is the code I'm running:
It looks up some values in the revision table and then puts it in some custom iProperties.
'xxx
'xxx
'xxx
' Set a reference to the drawing document.
' This assumes a drawing document is active.
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
' Set a reference to the first revision table on the active sheet.
' This assumes that a revision table is on the active sheet.
Dim oRevTable As RevisionTable
oRevTable = oDrawDoc.ActiveSheet.RevisionTables.Item(1)
' Iterate through the contents of the revision table.
Dim Rij As Long
For Rij = 1 To oRevTable.RevisionTableRows.Count
' Get the current row.
Dim oRow As RevisionTableRow
oRow = oRevTable.RevisionTableRows.Item(Rij)
' Iterate through column 2 in the row.
Dim Kolom As Long
For Kolom = 2 To 2'oRevTable.RevisionTableColumns.Count
' Get the current cell.
Dim oCell As RevisionTableCell
oCell = oRow.Item(Kolom)
' Display the value of the current cell
' MsgBox("Row: " & Rij & ", Column: " & oRevTable.RevisionTableColumns.Item(Kolom).Title & " = " & oCell.Text)
' Write value of current cell to the following iProperties
iProperties.Value("Custom", "NL_META_UITGAVE") = oCell.Text
iProperties.Value("Custom", "NL_META_CONTROL_DATUM") = oCell.Text
Next
Next
I hope some of you can enlighten me where this goes wrong.
